Me too
Same problem here. Q6600, Asus P5K, 2 GB ram, HD 1, PT 7.3 cs5.
I was using a Dual Core 930, Asus P5LD2(945 chipset) that worked fine. This is very bad, can not work with this problem. Ric |
question for all with this problem. does this problem happen when running sessions that came from a mac?
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
Can everyone experiencing this please post a Sandra report?
Also - do any or all of you have any networked drives mounted? Does unmounting those drives help at all? |
SiSoftware Sandra
System Host Name : INTELQUAD User : RAY Workgroup : WORKGROUP Processor Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Speed : 2.40GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Internal Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, Inclusive, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, Inclusive, 64 byte line size, 2 threads sharing System System : Gigabyte Technology Co., Ltd. P35-S3G Mainboard : Gigabyte Technology Co., Ltd. P35-S3G Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : 1 Processor(s) Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Award Software International, Inc. 255.255 Total Memory : 3.50GB DDR3 Chipset 1 Model : Giga-Byte (Bearlake) Processor to I/O Controller Front Side Bus Speed : 4x 267MHz (1.07GHz) Total Memory : 2GB DDR3 Memory Bus Speed : 2x 534MHz (1.07GHz) Video System Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce 7600 GT Physical Storage Devices WDC WD1600YS-01SHB1 165GB (SATA300, NCQ, 16MB Cache) : 153.38GB (C:) (E:) ST3500320AS 500GB (SATA300, NCQ) : 465.76GB (F:) (G:) ST3500320AS 500GB (SATA300, NCQ) : 465.76GB (H:) (I:) ATAPI DVD A DH20A4H (ATAPI66, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 117.19GB (72.84GB, 62% Free Space) (NTFS) @ WDC WD1600YS-01SHB1 165GB (SATA300, NCQ, 16MB Cache) C BACKUP (E:) : 36.19GB (13.69GB, 38% Free Space) (NTFS) @ WDC WD1600YS-01SHB1 165GB (SATA300, NCQ, 16MB Cache) PROTOOLS 1 (F:) : 232.42GB (174.97GB, 75% Free Space) (NTFS) @ ST3500320AS 500GB (SATA300, NCQ) PROTOOLS 2 (G:) : 233.34GB (90.32GB, 39% Free Space) (NTFS) @ ST3500320AS 500GB (SATA300, NCQ) SAMPLES 1 (H:) : 232.42GB (73.44GB, 32% Free Space) (NTFS) @ ST3500320AS 500GB (SATA300, NCQ) SAMPLES 2 (I:) : 233.34GB (36.39GB, 16% Free Space) (NTFS) @ ST3500320AS 500GB (SATA300, NCQ) CD-ROM/DVD (D:) : N/A @ ATAPI DVD A DH20A4H (ATAPI66, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache) Peripherals USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2934 USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2935 USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2936 USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2937 USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2938 USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2939 USB Controller/Hub : Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A USB Controller/Hub : Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Mass Storage Device USB Controller/Hub : Kore2 Controller FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard : HID Keyboard Device Mouse : PS/2 Compatible Mouse Mouse : HID-compliant mouse Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device MultiMedia Device(s) Device : Digidesign HD Core Device : Digidesign HD Process Device : Digidesign HD Accel Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD DSP Device : Digidesign HD Accel DSP Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 3) Platform Compliance : Win32 x86 Network Services Adapter : Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
to X9blade: From Mac or Pc makes no difference.
to Digisupport: No mounted network devices here. I smell a Video card -interrupt conflict here. Today I checked the machine with Everest looking for something and I discovered that two Digidesign DSP share the same interupt(16) with the video card. All the other DSP are in another interrupt (17). This interrupt issue is something I could never understand. Apparently nobody knows how to assign an interrupts to a device, so we are at the mercy of windows here. For example, I'd like to put the video card on a less shared interrupt or far away from the HD card. Any ideas? Ric |
#16
first please disable the usb 2.0 controller.
check your cpu-settings in the bios: C1E Enabled CPU TM FUNCTION Enabled VANDERPOOL Disabled PECI Enabled EXECUTE DISABLE BIT Enabled INTEL SPEEDSTEP Disabled @ricren: usb 2.0 controller: disabled lan controller: disabled your preferred pci-slot should be nr. 2! second try nr. 3, but nr. 1 is a no-go! for HD1 - HD2 PCI i can higly recommend the Asus P5KWS using both PCI-slots (not PCIX!) when you notice an irq-sharing conflict with one dsp you can deactivate this dsp in the hardware-manager. this is a workaround but should work. @x9blade: also do the settings, but i can´t see any irq listings for your mobo. thought gigabyte does also a good job on this. |
#17
I think this is a video card problem-
I had an ATI x1600 card which I reluctantly used because I pulled it out of another machine and it used to cause problems, but I didn't have any other PCIe cards when I built my new q6600 machine. . . I didn't have too many problems with it in that machine except that when plugins would pop up on the 2nd screen, touching a knob would occaisionally cause a crash. Also some wrapped plugins would cause crashes here and there. So I switched to a Nvidia card and now I am having this problem like crazy. It sounds like ring modulated sounds still playing after I hit stop almost everytime. It's better at a 512k buffer, but not by alot and one round trip with that buffer will throw an entire session out of realtime. I've always had the best luck with matrox cards in DAWs so I think I'll give one of them a go agian. Is anybody who is having this problem using a matrox? |
#18
I also suspect the problem is related to Nvidia drivers. I wish I had an ATI card to try. All our machines have Nvidia cards because I thought they would be more compatible.
Ric |
#19
it´s an IRQ-sharing problem.
some or at least one slot shares the IRQ with the graphics-slot. therefore pro tools cards can have a conflict and pro tools pops/clicks/loops when you´re scrolling inside the mixer or just turn a knob. for system with 2 graphics-slots it´s worth to try the second (often the lower) graphics slot for the graphics card. or you re-attach the pro tools cards. i recommend to start with the core card from the lowest slot continuing upwards. and attaching the interface to the last (highest) non-core-card. the flex cable starts at port A on the core card, to port B on the Accel/Process card and so on for other cards... |
#20
Re: playback looping error
I'm having the same problems and I finally got around to check the IRQs with Everest. IRQ 16 is shared by two DSP chips and the video card. I tried to disable the chips but I get a DAE error -1115 when I try to start Pro Tools. I'm on a Q6600 Nvidia 680i MB, and a cheap 64mb Nvidia Quadro video card. Anyone have any ideas? Thanks! |
turning looping on and off during playback? | George DAWs | Tips & Tricks | 1 | 12-09-2013 10:49 AM |
Playback and Looping Issue in PT 7.3 | tikki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-03-2007 09:38 PM |
PTLE 7.1 PLAYBACK NOT LOOPING | djpledge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-17-2006 11:40 PM |
Looping vocal while monitoring music playback | dougpotter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-10-2004 12:28 PM |
Loop playback not looping | Bixby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-16-2004 10:00 AM |
