Old 01-29-2007, 02:46 PM
Mike Harrison Mike Harrison is offline
Default Need to Remove the Lead Vocal from a Song
Can anyone recommend a plug-in or another method for removing the lead vocal from a stereo recording (song)?
Thanks!
Mike Harrison
Voice Actor/Narrator/Audio Producer
https://mike-harrison.com
Old 01-29-2007, 04:45 PM
BRH BRH is offline
Default Re: Need to Remove the Lead Vocal from a Song
I tried once or twice to do this with minimal success. Bring in the song to 2 mono tracks. Pan both tracks straight up-mono. Put the Digi EQIII on one of the tracks, and reverse the phase on it. It'll drop out the vocal, or most of it. You will still here any reverb left over.
Old 01-29-2007, 04:48 PM
VanAmp VanAmp is offline
You just need to flip the Phase of ONE channel of the stereo file.
Since most stereo recordings have the vocals dead center when one channel is inverted (left or right does not matter) the vocals will null and the things that are panned will not.
unfourtunatly the bass is usually centered as well so you might have to get a bit fancy with some EQ to help the track sound better.
Old 01-29-2007, 05:02 PM
BRH BRH is offline
That's what I said.
Old 01-29-2007, 06:46 PM
your a faster typer then me.
Old 01-30-2007, 08:22 AM
BRH BRH is offline
There's also some software out there to do this, and it was ...like $29.95 ...but I didn't spring for it. Forget the name of it, but looked cheesey. If some has a really good method, post it!
Lacey Thompson Vocal Eliminator could do it. never tried it though, but bought one of his products 20 years ago (Para EQ) and wasn't impressed.
Old 01-30-2007, 11:26 AM
req06 req06 is offline
man, this must be one of THE most requested questions on the DUC, Gearslutz etc....
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4
Processing the modern lead vocal scrnplyr Tips & Tricks 35 09-26-2013 02:40 AM
Suggestions on tracking lead vocal Keefriffhard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-24-2005 09:47 AM
Lead Vocal Plug In tomhartman Pro Tools TDM Systems (Mac) 27 07-23-2003 06:13 AM
In your face stereo lead vocal.... Anthemmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 03-15-2003 10:25 PM
Lead vocal question richie rich 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-31-2003 10:54 AM
