Old 01-28-2009, 03:32 PM
b mcgibney b mcgibney is offline
Default Can't turn off Mac Function keys/turn on PTLE Shortcut keys
Hi all,
I've having a heck of a time getting the function keys to work in PTLE.
Particularly F1 F2 F3 F4 etc to go through slip shuffle, grid ,spot etc.
I have made sure spaces /expose/dashboard/spot light are not activated
and in System Preferences -mouse keyboard/keyboard short cuts I have deselected everything.
But when running protools the keys either do not work at all or do the expose stuff. What the heck am I missing here. And yes I do have command focus on in the edit window when I'm trying this.
Tips or pointers to answers much appreciated
B
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers
Old 01-28-2009, 04:36 PM
flommer flommer is offline
Default Re: Can't turn off Mac Function keys/turn on PTLE Shortcut keys
In Keyboard Mouse preferences, there is a global setting for the Fn keys that makes you have to hold down the Fn key to access the expose, volume, etc functions that are mapped by default on the new, thin aluminum keyboards.
It is on the first tab (Keyboard, I think) of the preferences panel..
Then there are still the other ones that you were turning off in the keyboard shortcuts tab...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 01-30-2009, 09:44 AM
Thanks flommer , I'll give that a go!
Old 03-19-2009, 03:21 PM
wwittman wwittman is offline
AH, just found this
It's indeed in the KEYBOARD control settings, first tab and it's the CHeck Box called:
Use All F1, F2 etc. keys as standard function keys
it needs to be checked for PT function shortcuts to work
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Old 03-20-2009, 01:49 AM
Stiff Stiff is offline
Another way is to use the shortcuts...
option+1-4 is slip, grid etc.
cmnd+1-7...?...8? Something like that, is the tools.
Daily news & reviews
www.ProToolerBlog.com
Old 04-03-2009, 10:38 AM
Siegfried Meier Siegfried Meier is offline
I've just freshly reinstalled my Mac Pro, and I don't know what's going on but I can't use F1-F4 for the Shuffle, Slip etc settings. I have "use all F1, F2 etc. keys as standard function keys" checked off in keyboards. What else am I missing here? It worked fine for the last year before I reinstalled everything.
Using a new thin aluminum keyboard as well.
Thanks,
Sig
Old 04-03-2009, 10:53 AM
It's the new version of Quickeys. It has all these new shortcuts that take control - never were there before.
So, it works now.
Sig
Old 06-03-2009, 04:31 AM
budinski budinski is offline
This is great, I had the same problem and now solved by ticking that box! the only thing is that there is no function key short cut for smart tool? ANy advice please?
Budinski
Protools LE 7.4
Macbook Pro with external keyboard
Mac 0sx 10.5.4
MBox
Old 06-03-2009, 07:25 AM
Mad Psyentist Mad Psyentist is offline
Question Re: Can't turn off Mac Function keys/turn on PTLE Shortcut keys
Thanks,
Sig
My keyboard preferences don't even offer a checkbox for "use all f1..f2...keys as standard function keys." Just 'key repeat rate' and 'delay until repeat'.
System Prefs>>keyboard & mouse>>keyboard tab
I can get all the function keys working except the ones that toggle between the edit modes, f1-f4. I'm kind of stumped. This problem seems unrelated to quicKeys, because I just installed that program last night, and the function keys haven't been working since I installed PT 8 LE a month ago, even though they worked fine in PT 7.4.2.
I'm not using the aluminum keyboard, I'm using the standard wireless apple keyboard, which doesn't even have a "fn" key on it anyways. Any thoughts?
Old 06-03-2009, 07:35 AM
GeoffLee GeoffLee is offline
Smart tool f7+f8
Pressed some keys now shortcut keys wont work (T,R to zoom etc) Falcon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 06-11-2016 10:49 AM
XP SP2-turn off "hot keys"? Ken P Pro Tools TDM Systems (Win) 3 01-25-2006 10:02 AM
Function Keys on C8? dio ProControl, Control|24, Command|8 1 09-22-2005 08:15 AM
How about those function keys???? McMasters ICON & C|24 1 04-21-2005 02:50 AM
function keys don't work as quick keys miked45 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-21-2003 10:32 AM
