Old 01-16-2002, 03:35 PM
Datus Datus is offline
Default Alesis Ai3
Has anyone used the Alesis Ai3 box? It is an 8 in 8 out a/d box through ADAT Lightpipe standards, combined with the Digi001 setup theoretically should double your ins and outs. If anyone has used this let me know I am considering buying one to take better advantage of my hardware.
Stephen Tyler
Old 01-16-2002, 05:07 PM
Mark_Knecht Mark_Knecht is offline
Default Re: Alesis Ai3
Datus,
The word has been good on the AI-3. If you need mic pres than go with the DigiMax.
Mark
Old 01-16-2002, 06:05 PM
Mr Scary P4P Mr Scary P4P is offline
Here is the DigiMax
http://www.presonus.com/html/products/digima x.html
Here is one on ebay http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1501589296
Old 01-17-2002, 09:43 AM
Road_Hogs Road_Hogs is offline
I've been using an AI-3 for over a year and it has been a joy to use. Connection to the 001 is easy. Good bang for the buck, especially if you are dealing with line levels or have a mixer you can insert for the preamps.
Cheers,
Toby Gray
Old 01-17-2002, 09:36 PM
rfreeman rfreeman is offline
Same here. Been using it for a year. It really does double the chewy input goodness of the 001. Cost effective too. If you need preamps though, get the Digimax (alot more $$)
Old 01-18-2002, 01:27 PM
Mike Glenn Mike Glenn is offline
AI-3 works for me as well. Anyone using the direct outs on a Mackie board into the AI-3? If so are you setting the input lvel to -10 or +4?
Old 01-18-2002, 01:51 PM
Bastiaan Bastiaan is offline
mike,
Thre's an easy way of finding out. make a sound with the signal generator in ptle at -10 dB. Send that out to your mixingconsole. Set everything to unity on your mixer. Check the levels. Should read -10 dB (if not, change settings). Then route that signal back into ptle through an aux-track. Put a compressor on that aux-track to be able to get a db-scale. Look in there. If it isnt -10db.....change the settings.....
-10 db is consumer level, +4db is profesional level.
Bastiaan
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 01-18-2002, 01:59 PM
I will give it a try. Mackie tech support claims the mackie direct outs (1604vlz) are +4. When I set the AI-3 for +4 the signal is way too low.(gain adjusted on the mackie so input level reads 0db, fader at 0db)
Old 01-18-2002, 03:35 PM
Thanks for the feedback, I figured if its from Alesis it would be good. I love my QS8, and I want an Andromeda....sooooo bad...
Stephen Tyler
Old 01-18-2002, 03:39 PM
mike,
Are you using balanced or unbalanced cords....
Bastiaan
What's that?
Bastiaan
Alesis DM5 and SD2 Hamdi The Drum Room 1 04-05-2011 09:52 AM
888/24 vs Alesis AI-3 smack Tips & Tricks 2 03-25-2003 07:07 PM
Alesis AI-3 Duhduh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-26-2002 08:33 PM
alesis ai3 stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-01-2002 04:32 PM
alesis qs6 hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-01-2001 04:06 PM
