Old 05-18-2001, 01:58 PM
KingTor KingTor is offline
Default insertion follows playback
gee, wouldn't it be nice if there was a button on the procontrol that controlled insertion follows playback? wouldn't it be even better if that button lit up to indicate which mode it was in? like maybe if I could reassign a button that I never use (like "audition") to do that?
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 05-19-2001, 10:06 AM
Mark Haliday Mark Haliday is offline
Default Re: insertion follows playback
yes yes yes !
Being able to switch rapidly from "insertion follows playback" to the other modes would be great since this has great impact on the way ProTools behaves.
Great suggestion
Mark Haliday
CUSTOM STUDIO
Paris, France
Old 05-19-2001, 11:50 AM
barden barden is offline
Technically speaking, there already is a shortcut key that achieves this. If you have command key focus turned on, the "N" key on your keyboard toggles the Insertion Follows... mode.
Now, that isn't to say that I wouldn't love to see a key on Edit Pack that lights up to give immediate reporting of this mode, but at least there is a single key that sets it instead of navigating through the Preferences window.
Prior to using the command key focus, I had a Quickey programmed to achieve the same result. That would be another potential solution.
All the best,
Stephen Barden
Supervising Sound Editor
Sound Dogs
PT2022.12
EuControl 2022.12
macOS Ventura 13.1
MacBook Pro (16-inch, 2021) M1 Max 32GB RAM
HD Native / HD OMNI / Dock / S1
www.imdb.com/name/nm0002486
Old 05-20-2001, 12:31 AM
Thanks for the feedback !
although I have RTFM from cover to cover god knows how many times for the past year I haven't got to using command key focus yet, nor the quickey feature. Guess I will have to roam around the manual again !
Thanks again
Mark Haliday
CUSTOM STUDIO
Paris, France
Old 05-20-2001, 09:56 AM
Weird huh? I really resisted Command Key Focus when it was introduced...don't really know why. I think I felt a certain amount of pride in being able to operate the software pretty efficiently after using it for so many years "as-is" or with using third-party add-ons like Quickeys.
But, I have to admit, once I started looking at it closely and realized that there were several things that I could do with Command Key Focus turned on that I couldn't do without, I began to get turned on to it.
For example, here's another good one - moving your insertion point or an entire selection *vertically* from one track to another. It can be done with Pro Control easily, but it can also be done within the software only - as long as you have Command Key Focus turned on. That one has made a huge impact on the way I work - copying and pasting sections of automation for example.
Anyway, check it out if you get the chance.
Gives a new perspective on a piece of software that we have all been using similarly for several years!
All the best,
Barden
Sound Dogs
PT2022.12
EuControl 2022.12
macOS Ventura 13.1
Old 05-22-2001, 04:23 PM
chumpler chumpler is offline
Stop being a woman and hit N .
Queen Thor. If you want to complain about something complain about the Westlakes or that Scotty guy under your desk.
Playback insertion problem?? Smithcok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-15-2009 04:03 PM
Insertion follows playback weirdness tdowning 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-16-2006 06:10 PM
Insertion follows playback. Seeee Pro Tools TDM Systems (Mac) 2 03-13-2006 04:41 PM
"timeline insertion follows playback" BinkBonk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-26-2005 12:18 PM
timeline insertion follows playback pref KEITH MC DONNELL Pro Tools TDM Systems (Mac) 8 05-09-2001 10:48 AM
