Old 08-08-2012, 08:58 AM
JazzyJ JazzyJ is offline
Default Blank file after Audio Suite render?
I've seen some posts from 2009 with the same problem but no solution.
I render/process an audio file in AS and the resulting file is blank.
Sometimes if I create a new track and drag the clip on to that and then apply the same Plugin it will process normally, other times not and thus I'm here asking for a solution.
All plugins are up to date (way more up to date since PT 8.0.3 was released) and this problem sometimes comes, sometimes not.
Any ideas?
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Elastic Audio can't render-then loses audio file boneboy macOS 5 04-30-2014 04:57 AM
Audio files on one FW Drive render blank audio files when copied ridmik Digidesign Hardware & Software 4 03-30-2012 12:55 PM
Digi Suite Plugs come up blank? Bobby P Pro Tools TDM Systems (Mac) 4 03-18-2009 05:31 PM
Sans-Amp Audio Suite empty file Porky Pro Tools TDM Systems (Win) 0 01-21-2009 09:24 AM
Audio Suite Plugins Don't Render! Superbee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-30-2001 12:00 AM
