Old 05-07-2012, 01:01 PM
adjectives adjectives is offline
Default Nothing coming out of 11R Main Outputs
Just picked up two Yamaha monitors to run from the main outputs of my 11R. Headphones are still getting a signal fine. I've been playing around with it for about 2 hours and I still can't figure it out.
Running out of Logic 8 but I also have Pro Tools to open up in order to play around with the 11R settings. When I start logic up my monitors got a "pop" so I know they're getting something from the 11R. I've tried setting individual track outputs to "5-6" but I'm not having any luck. Does anyone have any suggestions?
Running Mac OSX Lion, Logic 8 (also have Pro Tools), and running my 11R through USB.
Rick
How to use outputs 1-2 on Digi003 without getting main mix? se.audio Tips & Tricks 10 12-21-2020 09:16 AM
Amp outputs same level as Main outputs? DonaldR Eleven Rack 0 02-07-2013 01:50 PM
Those who go direct, Main outputs or DI box? Jd0g33 Eleven Rack 7 11-01-2011 08:27 PM
No audio coming from Main Out's of Digi001 mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-24-2003 08:06 PM
Use DIGI-001 as main outputs for Mac? birdFEEDER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-14-2003 12:02 AM
