Axiom 49 as a controller for Pro Tools 7.3
Hello everyone,
I am an avid user of forums all across the web and I did my due diligence by searching different forum first. I found serveral post from Axiom users who were seeking the same knowledge that Iam looking for and I followed every instruction (at least I think I did) to the "T" and repeated them several times before I decided to post. This is my last resort...... I downloaded both of those presets to use with Enigma. I uploaded the presets to my axiom, I preset that I found that were susposed to make the axiom controll pro tools I already had the CS-10 driver loaded in my pro tools because I use it for my 2 yamaha O1V's to act as fader remotes for pro tools, but I downloaded it again to make sure I had the latest version. I went to setup and then peripherals, then midi controllers and I selected the CS-10 driver and selected the Axiom port 1 for both send and receive, I then set it to 8 channels. I have tried it in every possible controller section from 1 to 4 and speciffically in #3 as instructed (what I did notice is that no matter where you put it if there is nother in #1 or #2 when you check back it's moved to #1) after all that I slected ok and NOTHING! I'm pulling my hair out, the little that I have. Quiet honestly I really just wanted to use the transport buttons on the axiom to control the transport in Pro-tools because like I said my O1V's more than suffice as fader controls.....So I even found a post that gave a link to the M-audio website with instructions on just setting up the transports to work by going into peripherals and Machine control, and selecting "enable MMC remote" and selecting preset 15 on the Axiom to get the transports to work.......... Well guess what the Play button works great! but none of the other buttons do, no stop, to rewind, no FF, no Record. No not even when I select Preset 1 using Stych69 xml file still no transport controll. As you can see, I think I have throughly followed all instructions to no avail. I have tried to give you as detailed an explanation of my actions as possible in hopes that you will be able to see my mistakes or what I neglected to do and bring them to my attention so that I can make this work. Even though I really just wanted transport control, now that I know that all these other things are possible I want it all to work because that means I can controll all of those things even when I'm away from the studio. Any help will be greatly appreciated Thanks in advance! Bashir |
Re: Axiom 49 as a controller for Pro Tools 7.3
Bashir,
Sorry that I have no answer for your problem, but perhaps you can help me with mine. I also have an 01V that I am trying to setup as a controller, just faders, but I'm having issues. First of all I am still looking into how to get the CS10 template loaded into protools. Maybe you can explain to me more on how to make this happen, would be much appreciated.... Thanks.
I have a dream that one day Avid will upgrade Pro Tools Markers tracks..... |
How to set up my axiom 49 midi controller with pro tools le8 on windows 7? | iva star | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-08-2010 10:26 AM |
axiom 25 as controller for PT 8 problem | harryk | MIDI | 11 | 03-20-2009 10:48 PM |
Help with Axiom Controller ...Please | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-27-2009 03:08 PM |
Axiom Pro controller | hki | Virtual Instruments | 0 | 01-16-2009 08:33 AM |
Axiom Controller confusion.....?????? | Paulthe3rd | Virtual Instruments | 1 | 01-10-2009 12:00 PM |
