Old 06-12-2017, 01:58 PM
SediRegtur SediRegtur is offline
Default Problem with elastic audio on multi-mic drums
Hi all,
I recently recorded drums for a band, after the recording the bandmembers decided the tempo was a little too slow, and should be raised from 122BPM to 127 BPM.
I have read the Pro Tools guide and watched quite a few youtube-vids, but most of them seem to be oriented towards sample-users.
Anyway, when I view the individual drumtracks in Workspace I see that the elastic analysis gives completely wrong and different tempos per track.
Most of them are pretty close to 122, some are quite far off. As a result, I run into all sorts of problems while trying to raise the tempo.
In workspace, I can choose to clear the elastic analysis, but after I do that and try to make the tracks conform to 122bpm-session-tempo, I'm back to the wrong analysis.
I honestly don't know what to do anymore, does anyone know how to get an accurate elastic analysis or how to manually set a tempo?
Huge thanks in advance!
Does anyone know how I can
Old 06-12-2017, 08:48 PM
Default Re: Problem with elastic audio on multi-mic drums
To change the tempo, you really don't need to view the markers. Just run this routine(starting at the original 122 tempo).
1-Consolidate all audio tracks so they all start at the same grid line, and end at the same grid line(so every audio file is exactly the same length)
2-Set all audio tracks to TICKS mode
3-enable Elastic Audio on your audio tracks using the appropriate algorithms(like Rhythmic for drums,Monophonic for bass/vocals, etc)
4-go to the tempo setting and change it to 127
5-cross your fingers, hit PLAY and see what you have
(not that all this never requires you to even see the WARP markers)
ELASTIC AUDIO Thumbs Down with Multi Track Drums davemartone Pro Tools 12 27 07-18-2016 01:38 PM
Elastic Audio Glitches on Multi-Track Drums travista00 Pro Tools TDM Systems (Mac) 13 06-09-2008 02:11 AM
Problems with Elastic Audio on Multi-track drums O.G. Killa Pro Tools TDM Systems (Mac) 28 01-02-2008 01:34 PM
How do i do use elastic audio across multi track drums... chucknkd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-03-2007 02:46 PM
elastic audio on multi track drums... asdfg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-15-2007 04:47 PM
