Sampletank 3: Other channels don't trigger when recording subsequent ones
Oops, make that Sampletank. Okay, so PT12.5 on Mac running 10.10.5 with 16GB RAM (Macbook Pro mid-2014). Using Sampletank 3. I'll record a drum part on an instrument track. Then when I go to do a bass part on a separate track, using the same instance of the plug, all mapped properly to the new track, the previous drum parts won't play whenever I'm hitting a bass note. Mind you, if I crank the HW buffer all the way up, the problem goes away. But then I lose the feel. Is it really that hard for PT to allow this to happen at a lower buffer setting? And of course, I can't freeze the tracks as I do them, without making a new instance of the plug on each track. But maybe that's what I have to do? And of course, this is only during RECORD. During playback, all is well. Alas...
Re: Sapletan 3: Other channels don't trigger when recording subsequent ones
Re: Sampletank 3: Other channels don't trigger when recording subsequent ones
No. What happens is, while in RECORD only, when I try record the bass part, the previously-recorded drum track does NOT play whenever I play a note on the bass. It's as if Sampletank can only handle notes from one or the other at a time. And yes, everything is set correctly. Separate out on Sampletank 3 for the two parts. Both routed to separate instrument tracks in PT. And funny thing is, when NOT in record, it WILL play all the notes. So I just have to soldier on and try to record the subsequent parts while not hearing the previous ones, and then check it out afterward.
I use a separate instrument track for each instrument because it allows you to mix each part as you would any regularly-recorded instrument. If I only used one instrument track, and fed each part into it via separate MIDI tracks, that control is lost. See the attached image. I've been doing it this way ever since plugs started allowing it. Only for some reason, ST3 won't/can't play back previously recorded parts while you're RECORDING a new one. And only while recording. Once you play it back, all is well.
The reason I say to use aux tracks is you don't need to have them in record ready to hear the output. |
But the whole point of an instrument track is to consolidate all that stuff into one. Instead of having, say, one instrument track with the plug on it, and then 4 MIDI tracks that feed thru that plug to 4 aux tracks (that's 9 tracks) you just have 5 instrument tracks, and done. It serves as both the MIDI and the aux track in one. Unless I'm missing something. Always a possibility!
Here's a look at how it works (for me) ideally...
https://www.dropbox.com/s/dr6p4zkmjq...%20PM.mov?dl=0 |
Okay, so what am I missing, exactly? The MIDI info is there, as it would be in a MIDI-only track. And the returning audio is there, as it would be in an AUX track. So what's the downside?
Live Recording Mackie 16 channels into 16 PT channels | 67Thunderbird | Pro Tools 10 | 22 | 10-26-2014 01:10 AM |
Trying to get a recording light to trigger automatically. | BillDog793 | Pro Tools TDM Systems (Mac) | 6 | 09-16-2010 06:59 PM |
Dropping Subsequent Videos BUG | jeremiahmoore | Post - Surround - Video | 2 | 03-06-2007 03:27 PM |
Trigger recording? | schreckmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-04-2004 10:09 AM |
trigger & recording | Waxxmaster | MIDI | 0 | 02-05-2003 07:35 AM |
