PT 10 Chokes bad on Midi keyboard input
Hello, I've noticed midi recording/playing on PT 10 really can't take much and often glitches (as in it hesitates for a second then throws all the notes out at once so timing is way off at times).
I'm in the process of upgrading to 12 but I really would like to fix 10 with this midi problem. I have no probs with recording audio or even using lots of plugs, just midi hell. Pro Tools 10 Mac Pro (Nice Titanium case before Flower Pot case) 16gb ram OSX 10.8 Command 8 Control Surface Sound Devices USB Pre2 Audio Interface Korg Controller Keyboard connected via USB to Mac Pro. T h a n k s ! |
Re: PT 10 Chokes bad on Midi keyboard input
In addition to the above questions, isn't the Sound Devices unit quite old? Just wondering if it's too old to have a proper/current driver?
More info could help.
What model is the Korg controller? Do you have another controller to test with? Can you launch Pro Tools with the N key to select the 'aggregate' engine to see if that behaves differently?
Hey Guys, sorry about the delay, here is the info you mentioned…
MusicMan691 Quote:
Processor 2.8 GHz Quad-Core Intel Xeon Memory 16 GB 1066 MHz DDR3 ECC Graphics ATI Radeon HD 5770 1024 MB Quote:
Host Processors = 4 Processors CPU Usage Limit = 85% Host Engine = Ignore Errors is checked Minimize Additional I/O Latency = Not Checked Delay Compensation Engine = Short Plug-in Steaming Buffer = Size Level 2 Optimize for streaming content on audio drives = Not Checked Quote:
Albee1952 Quote:
Jeffro Quote:
To launch Pro Tools with the N key Im guessing I just hold down the N key while starting Pro Tools? I tried that and I didn't notice any different outcome. The Midi still choked after noodling around for a minute or so. Maybe I didn't successfully start in Aggregate Mode? Here are some facts and things I've done: Ever since getting the Mac Pro I added a PCI Midi card to help share Midi duties in effort to avoid a MIDI problem like I am facing. I've tried the controller in both built-in midi and the PCI card and it behaves exactly the same on choking. I also have a Command 8 controller for Pro Tools which I plan to keep because I really dig this thing. I only use this for the faders, mutes, solo, and transport buttons. I've never ran audio through this unit but love it for what I use it for. Hopefully it's not causing any of this trouble. I couldn't see eliminating it as long as I use PT. Audio Interface = Sound Devices USB Pre 2 (Uses USB) Control Surface = Command 8 (Uses USB) Keyboard Controller = Korg K48=9 (Uses USB) Drums Controller = Roland V-Drums (Uses USB) But is usually off so it can't be the culprit. That's the only 4 usb things I have connected. I've tried switching them around between internal MIDI and the PCI Card MIDI. PT 10 chokes on Midi when even just playing without recording. I thought about adding a regular MIDI card to the MAC Pro so I wouldn't be using USB for MIDI on the controller. Does that sound good? I looked and couldn't find a PCI Midi board for MAC that doesn't have USB on it though. __________________ |
Bump |
No help? I'm sorry about the delay in me responding but I've been dealing with my father getting a new pacemaker and having to drive him to Little Rock Arkansas to have it done. He's back home and all is good so I'm ready to tackle my Pro Tools 10 Midi choke problem. Any further help? Jeffro? Anyone?
Pro Tools 10 Can't handle complex Midi ?
Hello, I've noticed midi recording/playing on PT 10 really can't take much and often glitches (as in it hesitates for a second then throws all the notes out at once so timing is way off at times). I'm in the process of upgrading to 12 but I really would like to fix 10 with this midi problem. I have no probs with recording audio or even using lots of plugs, just midi hell. Specs: I've been running v10.3.7 but will be updating to v10.3.10 before i install v12 so it'll be compatible. Mac Pro (Mid 2010) Processor 2.8 GHz Quad-Core Intel Xeon Memory 16 GB 1066 MHz DDR3 ECC Graphics ATI Radeon HD 5770 1024 MB I also use a Command 8 Control Surface Audio Interface is a Sound Devices USB Pre2 (No Midi on this) Korg K49 is my Controller Keyboard connected via USB to Mac Pro. PT 10 buffer and cpu settings: HW Buffer Size = 512 Samples Host Processors = 4 Processors CPU Usage Limit = 85% Host Engine = Ignore Errors is checked Minimize Additional I/O Latency = Not Checked Delay Compensation Engine = Short Plug-in Steaming Buffer = Size Level 2 Optimize for streaming content on audio drives = Not Checked I've also went through Avid's optimization checklist such as disable Wifi and much more. |
Re: Pro Tools 10 Can't handle complex Midi ?
First of all... glad your Dad's okay!
One of my rigs is similar, though that's running Pro Tools HD 10.3.10 on OS 10.7.5 (it's a Mac Pro1,1 with 10 GB memory). MIDI keeps up just fine for me and I've used a dozen different controllers with it. Currently using an Axiom 49. Have used built-in USB ports and a powered USB Hub. My typical settings: HW Buffer Size = 256 Samples Host Processors = 3 Processors CPU Usage Limit = 99% Host Engine = Ignore Errors unchecked Minimize Additional I/O Latency = unchecked Delay Compensation Engine = None Plug-in Steaming Buffer = Size Level 2 Optimize for streaming content on audio drives = unchecked Since this is HD I also have Disk Cache = Normal and Voices = 48 (1 DSP) Any other background tasks (Time Machine, Anti-virus, etc.) running?
I wonder if there are too many devices pulling voltage from the USB bus? Maybe try a powered USB hub for the keyboard and iLok?
Pro Tools Midi: External Keyboard Input to Piano Roll's Keyboard | SupreGlu | MIDI | 1 | 05-16-2015 08:26 AM |
MIDI input via computer keyboard. | vinylrider | macOS | 1 | 05-31-2013 07:27 AM |
MIDI input via computer keyboard. | vinylrider | macOS | 0 | 05-31-2013 07:15 AM |
Using your computer keyboard as input for MIDI | PaulG1522 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-03-2007 02:09 PM |
protools chokes on midi program change | rslander | MIDI | 3 | 07-06-2006 06:57 PM |
