Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 09-03-2019, 08:28 PM
banjo71 banjo71 is offline
Default Yahama-Steinberg UR44 and PT 12
I'm having trouble getting the UR44 to work on any other sample rate than 44.1kHz. Anyone know if the UR44 is even compatible with PT in general, before I waste a bunch more time with it? I'm working in PT 12.6.1 on a Windows 10 computer. I can bring up the UR44 ctrl panel, change the sample rate to 88.2 for some older sessions I have, check the Windows audio device panel for the UR44 and make sure the test button works for 88.2, and then launch an 88.2 session in PT. PT always brings up an error before trying to open the session that the audio device hasn't been configured properly. I've read the owner's manual on the UR44 and there's nothing that seems hard to understand. I would assume PT 12 is compatible but maybe not for version 12. Any ideas?
Pro Tools 12.6.1 for Windows 10
ASUS Core i7 3770
Yamaha Steinberg UR 44
Golden Age Project Pre-73 JR
Glyph 1TB GPT50 external drive - Firewire
JBL LSR305 monitors
Neumann TLM102
Equation F.20 condenser mic
SM81 condenser mic
Old 09-29-2019, 07:16 PM
Default Re: Yahama-Steinberg UR44 and PT 12
95% of the time, a stuck sample rate setting is due to Windows using the interface as its "default playback device". Go into sound properties and set Windows to use anything else for playback. That way, Pro Tools is not fighting with Windows for control of the hardware
Old 11-20-2019, 10:01 AM
I've found only one way to fix the problem with clock sample rate changes.. Let's say your last session was in 48kHz, and you closed and exited PT normally. And you want to run a session in 88.2kHz next. What I've found is that you need to open the control panel for the interface, change the sample rate to 88.2, and launch PT. Now if you create a dummy session in 88.2kHz and close it, you can now open any 88.2kHz session that already exists. If you need to go back to a 48KHz session, you need to close the 88.2kHz session, exit PT, go back to the ctrl panel for the interface, change back to 48kHz, relaunch PT, create a 48kHz dummy session, close it, and then you can reopen any 48kHz session.
I've tried all the other avenues, and this one works.
ASUS Core i7 3770
JBL LSR305 monitors
Neumann TLM102
SM81 condenser mic
Pro Tools 12 with Steinberg UR44 yazanjuve Pro Tools 12 11 04-23-2019 06:17 AM
AAE Error PT 12.3 UR44 hue Pro Tools 12 12 12-06-2015 10:41 PM
UR44 play nice with PT 11 in Win 8.1? serstickman Third Party Interfaces 3 06-10-2014 11:29 AM
MBox to Yahama MG166cx (mixing board) Hum arb232 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-23-2011 08:54 AM
Akai MPD26/ Yahama DJX-II ahromantic MIDI 2 06-12-2010 07:02 PM
