Re: 19.9 Still no Eucon Midi Ports.
So this is so simple, why cant Avid do this to help us out?
It's been mentioned a few times, that this is in the mix of fix... However, not as straightforward as one would imagine.
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
We think we may have found the culprit (a settings file was not getting updated correctly) Trying to get a fix into 19.9.1 this week.
Thank you Eddie! Please,please... check out deleting plugins via S3 config bug.
Sent from my iPhone using Tapatalk |
Unfortunately the fix had some side effects and deleted other midi devices so will have to wait until the next release later this year. The inserts issue might be in PT so probably in its release later this year too.
Thanks! At least we know it’s an issue.
Issue still not fixed.
Also, I can't seem to find a download link for 3.6.1 so I can try the workaround. |
What version are you running. This was definitely fixed in 20.1
20.1, though I have to keep running PT 2019.12.0 because of the OMF import bug.
I did do a fresh install of the EUCon unified workstation install. No midi ports show up in the SSL sigma application, or in my midi hardware window. Any thoughts on what I could be overlooking? |
Are you on Mac, Do you not see the Euphonix MIDI ports in the Mac Audio prefs. Have you assigned them in the EUCON Control Panel
ProTools 8.0.4 doesn't send MIDI to Yamaha S90 ES; midi out ports [Emulated] | bbirney | Pro Tools M-Powered (Win) | 8 | 05-19-2018 06:58 PM |
MIDI Virtual Ports not showing up in MIDI Controllers (8.0.5) | emiliojazz | Pro Tools M-Powered (Mac) | 0 | 02-18-2013 12:03 PM |
Three MIDI ports on DIGI 002R within MIDI studio Setup | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-18-2010 04:57 PM |
003 midi ports not there in midi studio setup? Unable to record midi now? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-22-2009 12:06 AM |
Anyone want to take a stab at why my MIDI ports keep disappearing in the MIDI Studio? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-30-2008 12:48 PM |
