Old 04-14-2014, 12:20 PM
1rons 1rons is offline
Default I/O & System Usage
In the process of running down why my sessions were choking, I discovered something interesting:
When I opened a relatively simple session for mixing, it choked when I hit play. I noticed the System Usage CPU meters were dangerously cole to 100%. When I opened the I/O window and deleted the labels on the inputs and reverted to the default, the meters dropped to below 50% and the session runs great.
Hmmm... What's up with that?
Ron Stephens
www.ronsongs.net
MacPro3,1 w/16Gb RAM, Omni , PT 11.1.2, OS 10.9.2
Old 04-14-2014, 01:16 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: I/O & System Usage
Really - wow / I usually delete all of the extra busses that I don't use but that's just b/c I don't want 5000 mono/stereo busses staring at me when I want to route verb
Daniel
Old 04-14-2014, 01:18 PM
I had relabeled the inputs to match my outboard mic press, etc...
Ron Stephens
www.ronsongs.net
Old 04-14-2014, 01:53 PM
YYR123's Avatar
Sure I do that as well / I label my busses and outputs. Then I delete the ones I don't use - I also usually save about 10-15 just in case I wanna do something wierd
Daniel
Old 04-14-2014, 02:10 PM
Maybe the I/O Label file was corrupt? I'll try renaming the default list and see if the CPU still maxes out.
Ron Stephens
www.ronsongs.net
Old 04-18-2014, 08:01 AM
Artysan Artysan is offline
Whenever I have suspicious behavior like that, I open a new blank session and import ALL session data from the suspect session to it. Save as and replace the bad session once you are up and running with the imported data. Works for me virtually always. Don't delete prefs! I can't believe how often people recommend that. It's like moving into a new house every time a window gets stuck.. Just dumb..
Peter Yianilos
Artisan Mobile Recorders
Old 04-18-2014, 08:07 AM
I'll give that a try. Thanks!
Ron Stephens
www.ronsongs.net
Old 04-18-2014, 08:49 AM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
I think its more like having you house cleaned, but then having to put back into place all your knick backs, but still the house is clean...
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Old 04-18-2014, 08:53 AM
JFreak's Avatar
JFreak JFreak is offline
If you want to have a setup with gazillion i/o routings, just do it once and export it to a file. Then clean it up and use fewer i/o in your sessions. And whenever you want to have all of them available fast, just import your gazillion i/o setup and it's all there again.
Janne
How come my system usage just keeps going up? sb_stefan Pro Tools 10 10 02-25-2013 09:37 AM
Good System Usage/RTAS settings for Quad Core system Mental Clarity 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-19-2008 03:09 PM
system usage.... gooner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-22-2007 10:52 AM
HTDM not showing CPU usage in the system usage Brandonx1 Pro Tools TDM Systems (Win) 3 12-19-2004 09:45 AM
System usage Studio Freak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-01-2004 04:32 PM
