Pro Tools SE Keeps Freezing! HELP ME!
4 Weeks ago I purchased Avid Vocal Studio. In the kit it came with Pro Tools SE Version 8.0.3. I have been installing it and uninstalling it over 10 times and it always freezes up on stage 2. Its at the point where you choose the device you want to install with it. I select the M-Audio mic and click next then nothing happens and just freezes on that. Please, can someone help me with this so I can start using my equipment?
Re: Pro Tools SE Keeps Freezing! HELP ME!
Same thing happens for us, but I was told to just wait.
It does this when we start an mp3 or wav export, which in version SE, takes as long or longer than the original recording. After coming back the NEXT DAY, protools SE had finished the export and was responding again. |
You should check the PC resources I think less than 2GB Ram the software might have an issue. Also if one uses an unistaller application like "Revo Uninstaller" and select the option to delete the registry keys and reinstall Pro Tools SE resolves some issues. I found that an anti virus, software firewall or anything that uses computer resources is better not to have running, maybe even during installation. I think the issue is the USB Producer mic drivers, one can also go to the hiden icons in the task bar and double click the m-audio icon it will open the driver mixer panel. There you can play around with the driver pre amp volume maybe just adjusting this might also resolve the issue. You can also adjust the pre amp imput level through the mixer panel. But the best thing is a clean reinstall. Hope it helps... Monkeysticker |
Pro tools SLOW, and Freezing then continuing, then freezing again | DJX-RAY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-09-2011 07:52 AM |
Pro tools freezing | Israelbujano | Pro Tools M-Powered (Win) | 0 | 12-26-2010 06:14 PM |
pro tools 8 keeps freezing | mindgone5150 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-17-2009 09:46 AM |
pro tools freezing...out of nowhere | daryl eakins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-20-2006 09:30 PM |
Pro Tools LE 5.2.1 keeps freezing | jaycoh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-09-2004 03:50 PM |
