Old 05-04-2007, 07:47 AM
Carbon Filter Carbon Filter is offline
Default Adding another 888/24 to mix plus system
I am having trouble adding a second 888/24 io to my mix plus system. I have all the neccessary cables and I have had the system running rock solid for a long time. most recently I have jut wanted to add an additional 8. The isssue is when I connect the 2nd 888/24 to to Y cable port B and I start up protools a screen comes up saying "please turn on digidesign interface and hit ok when ready". Obviously the 888's arealready turned on, word clocked and all the necessary changes have been made in the hardware set up. I know the 2nd interface is functional becasue it has come from another mix plus system. I just want to see if I am missing something. Any help fromsuer with similiar set ups would great
thanks
Old 05-18-2007, 01:12 PM
Default Re: Adding another 888/24 to mix plus system
solved
Old 09-19-2007, 05:16 PM
simplemix simplemix is offline
Please tell me how you fixed the problem. I have the same situation for 3 months and can't figure it out.
thanks
Old 01-28-2008, 09:04 AM
Actually the problem still exists. The problem seems to be that the 888 24 I/Os want stay in stand alone mode even on boot up or even when I change it to the correct settings in hardware set up. I have both interfaces hooked using the Y cable into the mix farm.
Note: the system runs rock solid with (1) 888 24/io connected but when I connect the other interface via Y cable both interfaces go into stand alone mode and Pro Tools will not start.
Operating system: Mac OS 9.2.2
Memory: 768
Serial# XB2401TAMMA
MAC OS ROM 9.5.1
Disk Cache 512k
Backside L2 cache: 1MB
Processor Speed: 1000MHZ
2 - processors
Software bundle : 694-4782
Sales order number: M8689LL A
Pro Tools 5.1.3
Mix Plus system
Mix Core and Mix Farm card
2- 888 24 I O connecting with Y cable
Any help from would be appreciated.
Old 02-01-2008, 08:13 AM
erikloesch erikloesch is offline
You got the bnc cable between the interfaces for slave clock ?
Erik
Old 04-29-2008, 03:42 PM
Powercage 9000 Powercage 9000 is offline
I'm having the same problem adding an 882/20 to my set-up! G4/OS9/MixFarm/Core/5.1.1TDM. I was sure it was the eBay-bought Mix Farm Card malfunctioning but maybe I just need a BNC cable to clock them together??? It's not a hardware prob cuz the 882 works when plugged into the Core card...the IO Setup and hardware is config. is all solid. I do think the 882 is operating in stand-alone mode also. Misery, sweet misery. At worst, could a Y-Cable run both interfaces off of the Core Card???
rock, evan
Old 05-06-2008, 10:58 AM
stonehenge stonehenge is offline
Carbon Filter - Do you have Slave Clock Out from the first 888 connected to Slave Clock In on the second 888?
Powercage 9000 - Do you have the Slave Clock connection, as well as a TDM cable connecting the MIX Core and Farm cards (inside the computer)?
Old 05-06-2008, 09:15 PM
milesofwire milesofwire is offline
I think I know what to do, Go into "Playback Engine" and select the interfaces from there, That should work, Please post your results.
Old 05-21-2008, 09:21 AM
soundblaster soundblaster is offline
Do you have a SYNC.
You will need a SYNC to have a common word clock for the additional 888s.
The SYNC will send a common time signal. The way you connect is use the BNC from the SYNC clock out and daisy chain the other 888s- from out to in on the next 888.
I hope this helps.
Cheers...
Can anyone help me with my problem please see TDM mix plus 3 24 I/Os but only get 16 I/Os.
Thanks.
Old 06-23-2008, 02:10 PM
rockstarj9 rockstarj9 is offline
I am having a problem with my system too. Any help would be appreciated. Here's the sitch:
I have six 888 interfaces all connected to the Mac with 3 mix cards (1 core card and 2 farm cards). The last two interfaces have a loud solid pink noise coming through that I can't isolate. I tried switching the cards around to see if that was the problem, but all that happens is there is no signal coming through when I put an instrument in, and the VU's keep jumping randomly on all the channels with no actual sound coming out. It's either a clock, sync, or an unknown frequency that I can't hear. Any idea what this could be?
Thanks in advance.
HTML code is On
OT: Adding UAD-2 RTAS to HD system. lownotesinc Pro Tools TDM Systems (Mac) 1 10-19-2011 12:25 AM
Adding a second LE system to Venue MikeTrahearn VENUE Live Sound Systems 2 12-06-2008 10:31 AM
Adding MIX cards to PT System byronfunk Pro Tools TDM Systems (Mac) 1 05-29-2007 10:18 AM
Adding ram to DIGI 001 system jcress 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-04-2004 07:24 AM
Adding a PCI Graphics Card to PT HD2 System Stacey Pro Tools TDM Systems (Mac) 1 04-23-2003 02:05 AM
