Old 07-26-2006, 04:15 AM
jill_m jill_m is offline
Default Avid Mojo and Pro Tools 7.1 HD Integration
I have recently purchased a Mojo and a new HD setup for the studio. The only way I seem to be able to get video to output to my external monitor is if I capture it into Pro Tools or if I export a linked video OMF or AAF from Avid's Media Station software. With Media Station the importing process can be quite long so I'm hoping to skip this step. What is the file type that Pro Tools needs in order to play video out of the Mojo? I've tried many DV formats that I've exported from Quicktime Pro, none work. Is there a specific file type that I can ask my clients for rather than having to go through a lengthy conversion process? I'd like to not have to use Media Station at all.
I've found info on the Pro Tools site (see below) and it hasn't been much help. Apart from this there doesn't seem to be much other information floating around between the Avid site, Digidesign site and this forum. If anyone could help I would really appreciate it.
Thanks for your time.
Supported Video Resolutions
Pro Tools with Avid Mojo supports import and playback of any combination of the following video resolutions created with the Avid DV, JFIF or MXF video codecs:
1:1 (Uncompressed JFIF/MXF)
DV50
DV25 4:1:1
DV25 4:2:0
DV25P 4:1:1
DV25P 4:2:0
15:1s 4:2:2
14:1P 4:2:2
28:1P 4:2:2
35:1P 4:2:2
Old 07-26-2006, 05:16 AM
soundproof soundproof is offline
Default Re: Avid Mojo and Pro Tools 7.1 HD Integration
Hello,
Mojo only supports Avid video... So you can't play QT movies directly. Converting with MediaStation is the only way to go..
Old 07-26-2006, 07:59 AM
Hello,
What is the extension of an Avid video file? What kind of a format is it?
Old 07-26-2006, 08:32 AM
Craig F Craig F is offline
7.2 opens Mojo to just about any QT format ever used
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 07-26-2006, 11:23 PM
Mario C Mario C is offline
I don't know that you can ask for extensions, per se. If your video is originating on an Avid, just ask for one of the resolutions on that chart you listed. They send you an OMF or AAF (AFF?), you import and away you go. Avid formats are pretty much just Avid, as far as I know.
(If you really want to know, Avid media I've seen use the extension *.omf.)
If the video is not coming from an Avid, then the only way I know to get it into my Mojo is from QT, then convert it with MediaStation (like you have been doing).
And, like was just stated, with 7.2 we will be able to use QT directly through the MOJO without any conversion.
Hope this helps. If I'm inaccurate, someone please enlighten us
Mario C
Metcom Studios
www.metcomstudios.com
Old 07-31-2006, 03:40 PM
JanuS JanuS is offline
When picture is edited in Avid, you can ask for a picture OMF...
OMF version 2.0 should do the trick. In my experience the picture OMF came non-embedded, thus with
linked video-files. Just import OMF with "import session data" command, and it works perfect, and on the
right timecode! (That was a struggle for me as wel, putting the clips in MediaStation on the desired timecode...)
I hope this helps! You can skip the Mediastation in this case...
Jan
Old 08-02-2006, 09:33 AM
DigiTechSupt's Avatar
The video file formats that Avids, as well as Pro Tools with Mojo, use are OMF or MXF. Avid video files will either have an .omf or an .mxf extension.
When digitizing in Pro Tools via Mojo or V10 the video files created are MXF (they'll have an .mxf extension).
QT Pro is not able to create these files. Other apps/devices that create MXF, other than Avids and Pro Tools, will create Avid/Pro Tools compatible MXF video media including the new Panasonic HD video camera, etc. (although I'm not sure that any of this has been tested or is officially supported in Pro Tools... but should work just the same).
As already mentioned, Pro Tools 7.2 will allow you to import QT movies at just about any resolution (not all QT resolutions have been tested so it's possible that some could create problems) and play it back through the Avid Mojo with out converting it first.
Pro Tools 7.2 should be available very soon, keep your eye on the Digidesign website.
Jon Connolly
Digidesign Product Specialist
Avid Audio Tech Support
Support FAQ
HTML code is On
PRO TOOLS 7.4 and AVID MOJO SET UP!!!! stereocilia Post - Surround - Video 2 03-16-2009 11:36 AM
Mojo system integration question + MXF bug digartisan Post - Surround - Video 3 09-18-2006 10:37 AM
Pro Tools/Avid Integration Problem Mind2Matter Pro Tools TDM Systems (Mac) 1 02-22-2006 11:13 AM
Using Avid Mojo with Pro Tools 7 wallygrant Post - Surround - Video 7 01-07-2006 05:15 AM
Pro Tools TDM 6.6r2 for Avid Mojo on OS X Avid Post - Surround - Video 0 12-22-2004 05:06 PM
