Volume control for audition output?
Has anyone figured out how to rout audio through a fader when auditioning clips or using Audiosuite so you can reduce the volume? It is always ridiculously loud and I prefer not to change the master volume control unless absolutely necessary.
Gary Gegan |
Re: Volume control for audition output?
Interesting! Thanks so much for the tip. And once the audition level is changed it stays that way even though the Import audio window is not open?
Wouldn't it be nice if the level control was controllable from the Audiosuite plugin window or the Clip Bin?
Gary Gegan |
What am I missing here? It is, right? Little volume number on the lower left hand part of the AS window.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
I'll check it out. I have never noticed it or used it.
Gary Gegan |
Yep it's there and when you click on it a fader pops up. Never realized it was there. It also controls the audition volume for the clip bin as well. Thanks, Brandon! You learn something new every day.
Gary Gegan |
No problem. Glad I can help
Actually you find this is on top of any workspace/digibrowser window. Just click on the value next to the little speaker button
Output Volume. Amp Out control resets to zero | shaker | Eleven Rack | 3 | 09-13-2014 07:25 AM |
Audition/Preview volume adjustment? | Farmer Dave | Pro Tools TDM Systems (Mac) | 5 | 06-27-2013 03:31 PM |
audition output | Devin Emke | Pro Tools TDM Systems (Mac) | 2 | 09-15-2003 03:11 PM |
can't control audition output | c-post | Tips & Tricks | 2 | 03-18-2003 09:30 PM |
Need HELP ! output volume control problem | Drakon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-30-2001 01:45 AM |
