Old 10-21-2019, 07:47 PM
[email protected] chadm20@att.net is offline
Default 2019.6 freezes every 5 or so seconds
I've been running 2019.6 on an Mbox2 on a new beefed up PC Quad I7-7700 CPU, 16 GB RAM, all SSD drives 1 for the OS another for data and it worked like a charm, was so much faster than ever before but overnight it went down the drain. Worked great last night and today whatever I do it freezes every 5 seconds or so for roughly a second, the counters stop and the scroll line stops, Audio continues usually but sometimes it just stops. It's almost unusable now. No new hardware or software installed in the last couple of months so it's out of the blue. Anyone else seeing this?
Old 10-21-2019, 09:26 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: 2019.6 freezes every 5 or so seconds
What troubleshooting/optimizations have you done so far?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-22-2019, 05:12 AM
off the wall's Avatar
I'm not a PC guy but it sounds like some other PC/OS process is either spiking the CPU or accessing the disk. I get a similar thing on my Mac if I forget to delay the two backup processes I run while using Pro Tools.
offthewallproductions
Old 10-22-2019, 05:35 AM
JFreak JFreak is online now
Hi, welcome to the community.
You do realise your interface is unsupported on 2019.6, don't you? Its latest Windows drivers are from 2011 and support Windows 7/8 not W10
As said, please tell us what troubleshooting / optimization you have already done, also take a look at the Help Us Help You document linked on the forum header.
Old 10-22-2019, 06:24 AM
I understand the interface is not supported but it worked fine for 3 months and then this? The drivers are 2013 not 2011 but still old.
I uninstalled PT, reinstalled, no change. I run it with nothing else running, no change.
I did all the optimizations in the online AVID writeup and still the same.
Guess it's time for a new interface unless someone comes up with the magic wand.
Chad McManus
Old 10-22-2019, 09:22 AM
Found the issue, thanks for the responses. I said I didn't install anything but I was wrong I had a cassette to USB device for recording tapes to MP3 using Audacity. I don't think Audacity was the issue because it's still installed and all is well but I removed the USB PNP entry in device manage that was created when I plugged the cassette unit in and now all is well. Thanks again.
Old 10-22-2019, 06:49 PM
TOM@METRO's Avatar
Great. Thanks for coming back and explaining your solution.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
ProTools 2019.6 HDX Recording freezes but System and Software stay responsive Flo B Windows 0 07-19-2019 07:16 AM
OLEDs only show fader values for 1-2 seconds, then jump back to track names 2019.5 yoerik Avid S1, S3, Dock and Control App 3 06-10-2019 09:59 AM
Pro Tools 11 Saving Freezes for 30 seconds JonMiller Windows 43 12-18-2014 12:34 PM
session "freezes" for a few seconds when I hit the record button Reinaldes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-23-2009 07:26 PM
6.1 freezes appx 20 seconds into record mode MrShayne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-03-2003 06:14 AM
