Old 05-18-2019, 07:43 PM
abt abt is offline
Default 2019.5 Hardware inserts cause huge delays
When I say huge delays I don't mean latency, I mean everything grinds to a halt for 3-4 seconds and I can't do anything.
This happens mostly when I do things on an insert like add a new plugin, close a plugin, remove a plugin. If I load a new plugin everything completely freezes for 3-4 seconds.
If I remove all hardware inserts everything is fine.
It also doesn't matter which track I'm on, if there's a hardware insert in the session it happens.
Old 05-19-2019, 12:40 PM
Default Re: 2019.5 Hardware inserts cause huge delays
Tough to comment with zero info on anything. I would uninstall and go back to the last version that worked well
Old 05-19-2019, 02:21 PM
BScout BScout is offline
Let's start with the basics: what is your audio interface?
Old 05-19-2019, 02:25 PM
abt abt is offline
HD Native card
HD OMNI interface
OS: Microsoft Windows 10 Pro
OS Version: 10.0.17134 Build 17134
Mainboard: Gigabyte Z370 HD3
Processor: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz, 3696 Mhz, 6 Core(s), 12 Logical Processor(s)
RAM: 64 GB (4 x 16GB) PC4-19200 2400MHz DDR4 RAM
GPU: NVIDIA GeForce GTX 1070 Ti
Old 05-19-2019, 06:50 PM
abt abt is offline
Update. It's a problem with delay compensation. If I turn off delay compensation then the problem stops.
With delay compensation on it only happens if there is a hardware insert on one of the tracks. If I remove all the hardware inserts then the problem is gone.
Old 05-20-2019, 12:55 PM
del cosmos del cosmos is offline
No problem here using several hardware inserts.
Protools HDX(x3) High Sierra, cheese grater mac pro, magma expansion chasis and 6 i/o interfaces.
Old 05-20-2019, 03:43 PM
arche3's Avatar
arche3 arche3 is offline
Same here. Almost exact same setup. No issues.
Sent from my SM-G975U using Tapatalk
Low latency monitoring with HW inserts still broken in 2019.5 XJENSEN Pro Tools 2019 0 05-09-2019 12:03 PM
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
Hardware Inserts CosmicJunkie Pro Tools TDM Systems (Mac) 1 11-20-2007 03:12 AM
Hardware delays for vocals MidnightFlyer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-04-2005 09:42 PM
huge delays when I press 'record' Faulty Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 04-27-2003 07:18 AM
