Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 11-16-2018, 02:02 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Default internal sata drive doesn´t show up after restart
I run a dualboot system (Mavericks / Sierra), both on a dedicated internal ssd. I bought a new internal hard drive (Western Digital WD Black 4TB) for Libraries / Samples.
After starting the mac all disks show up but if I choose to restart from the other system-drive the Western Digitak Disk doesn´t mount and it´s not shown in the disk utility, too. I have to shut the mac down. Then after rebooting all disks are back again. Also if I do a restart but not changing the startup disk the disk comes up without problems. So the problem only occurs by doing a restart by switching the system drive.
Does someone have any advice how to fix this issue ?
Thanks in advance
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 11-17-2018, 05:37 AM
tonwurm's Avatar
Default Re: internal sata drive doesn´t show up after restart
no one, no idea ?
Ultimate HDX
Old 11-17-2018, 03:29 PM
Tweakhead Tweakhead is offline
What is the specific format of this problematic drive ?
Did you do it yourself, or just use it as it came out of the box ?
Old 11-18-2018, 02:30 AM
tonwurm's Avatar
thanks for answering
I put it in one of the internal drive slots of the mac pro and formatted it with disk utility
I attached screenshots with system information about this specific drive
Ultimate HDX
Old 11-18-2018, 05:13 AM
Thanks in advance
I dual boot my 2012 MacPro into either Yosemite or Sierra and my drives all show up okay in Finder and Disk Utility. I don't have them show on my desktop though. I have two WD Blacks 4 TB each with 64 meg cache - yours have the 128 meg cache in the internal drive bays 1 and 3. I boot from a Samsung 850 EVO 1 TB that sits on a pcie adapter card and that ssd is split into two equal boot partitions.
I don't understand something - are you booting off two separate drives - one for Sierra and the other for Mavericks? If so where are those drives? It looks like you have five drives which would mean you either have one ssd on a pcie card or a drive sitting in the lower optical drive bay.
Where are you selecting which drive to boot off of? System preferences or holding down the option key on bootup?
Jack
QAPLA!
Old 11-18-2018, 10:27 AM
I don't know why it is displaying an MS-DOS FAT32 Volume.
I would reformat as 1 partition.
Note: I hate the Sierra Disk Utility, so reboot into Mavericks.
Launch Disk Utility.
Select the actual mechanism.
Choose the Partition tab.
Create 1 Partition - Mac OS Extended (Journaled)
See if that gets rid of that weird EFI (MS-DOS FAT32) & POOL 2 split.
Old 11-19-2018, 01:12 AM
tonwurm's Avatar
Yes this is correct . I have 5 drives using in addition the lower optical drive bay. I have for Sierra a dedicated ssd drive in one of the internal bays and also a seperate ssd for mavericks. I switch the boot drive with a apple script that I found in the web since I cannot selct in mavericks the sierra drive as startup volume. Sometimes I also use the option key during startup which also works
Thanks for answering !
Ultimate HDX
Old 11-19-2018, 01:14 AM
tonwurm's Avatar
Strange ... all my internal drives have that EFI partition and running since years without problems. But I will try that. Thanks !
Ultimate HDX
Old 11-19-2018, 04:11 AM
But which procedure is giving you the problem? Using the script you found on the web (who knows how safe/good that is?) or the option key on boot up? I would stick with the option key on boot up. It takes a little longer to bootup but is a known good method. And I'm guessing the Mavericks ssd is also in a drive bay right?
Jack
QAPLA!
Old 11-19-2018, 04:23 AM
tonwurm's Avatar
I wrote it in my first thread post: after the mac was completely shut down and then start (no matter from what system drive) all drives apear correctly. And there´s also no problem if I then restart from the same system drive again. All drives appear then, too. BUT if I restart the mac from the other system drive than that which is currently running (f.e. Sierra is active and then restart from Mavericks) this very WD 4TB drive doesn´t appear again. I noticed that the drive doesn´t spin up.I have to shut the mac down and restart to make it active again
Ultimate HDX
Better to record to a FireWire drive? or 2nd Internal SATA HDD? conrad787 macOS 13 06-21-2012 08:52 AM
ProTools Boot drive migration to a new internal SATA drive audiowave Pro Tools TDM Systems (Mac) 1 05-03-2011 03:45 PM
PTLE w/ Mac Pro - Internal SATA drive order? salmonsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-07-2008 05:57 AM
Another Firewire Drive or Internal SATA II Drive??? fenderguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-14-2007 01:44 PM
External Drive writing to Internal SATA Drive Teen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-16-2007 07:29 AM
