Old 04-13-2012, 02:22 AM
jimfisheye jimfisheye is offline
Default damaged sd2 file recovery needed
I have a bunch of sd2 files that likely lost the resource fork of the files. So the audio data should still be fine. Is there some app that can write the big endian pcm data as a wav file? Or regenerate the header or whatever is easier?
Old 04-13-2012, 09:02 AM
matt-o- matt-o- is offline
Default Re: damaged sd2 file recovery needed
I think soundhack can regenerate the header, but it's long time ago, since I did it the last time... and there is a app called sd2 fixer:
http://mac.softpedia.com/get/Utilities/SD2-Fixer.shtml
read the caveats though...
greetings,
matthias
MacPro 7.1 8c 3.5 GHz, 48GB RAM, HD native
PT 2021.12.0, 10.15.7
www.imdb.com/name/nm0501611/
'save a copy as' damaged a file - file repair advice? Artysan Pro Tools TDM Systems (Mac) 8 03-26-2011 06:14 PM
Drive recovery or file recovery bobmaus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-13-2006 03:00 PM
-39 End-of-file damaged aiffs diegosaenz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-09-2005 10:28 AM
File Recovery Help Needed jnaz Pro Tools TDM Systems (Mac) 1 12-27-2002 09:04 PM
File Recovery Help Needed jnaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-27-2002 02:18 PM
