Old 08-20-2009, 07:06 PM
StinkyStan StinkyStan is offline
Default Help! -9129 and -9094 errors when bouncing.
Hi. My system has been pretty solid for over two years and today, I started getting the -9129, and -9094 errors when trying to bounce about 2 minutes worth of music. Playback is fine. The problem is ONLY during the bounce.
CPU usage cycles between 46% and 48%. Granted, I'm using some CPU-heavy plugins (Kontakt Player) and 5 amp sims with impulses loaded. Is this to be expected? I've tried the "dither trick" I read in another thread, but unfortunately -- no luck!
My system specs are below.
OS: WinXP SP2
CPU: INTEL|C2Q Q6600 2.40G 775 8M R
Motherboard: ASUS P5B P965 775
RAM: MEM 2Gx2|COR 240P TWIN2X2048-8500C5
Hard Drives: (2) 320G|ST 7K 16M SATA2 ST3320620AS
PTLE 8 cs2
Any help is appreciated. Thanks!
Old 08-20-2009, 08:00 PM
spkguitar's Avatar
Default Re: Help! -9129 and -9094 errors when bouncing.
5 amp sims? With impulses? Yes.
Print your amp sim tracks and see if it is any better.
The method I like to use is detailed in this tutorial on my website. You might find it useful.
Old 08-20-2009, 10:17 PM
Worked like a charm! Thanks!
Old 08-21-2009, 12:32 AM
pianosound pianosound is offline
Very nice site spkguitar!!
Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 |
Old 08-21-2009, 03:37 AM
Wango Wango is offline
This is a cool method.
I 'print' in a different way.
For tracks that require high CPU plugins, what I do is:
1) Duplicate the track
2) Select the whole track
3) Bring up the plugin
4) Tweak the settings to the desired effect
5) 'Process' the track
Then I mix the processed track in the usual way, blending the effected track in via an aux send.
Are there any advantages/disadvantages to this, compared to printing while recording?
Wango
Don’t piss down my back and tell me it’s raining.
http://www.soundclick.com/bands/defa...?bandID=851389
Old 08-21-2009, 06:14 AM
spkguitar's Avatar
One disadvantage to your method is that it takes twice as long.
One disadvantage to my method is that you cannot use "Low Latency Monitoring".
Old 08-21-2009, 08:26 AM
This is good to know.
I just picked up an amp sim a couple days ago, using it for my next recording.
Those things are CPU hogs but so far, with 2 amp sim inserts my cpu ain't breaking a sweat.
If I ever need to use more, this info will come in handy.
Thanks!
Wango
Old 08-21-2009, 11:43 AM
Ultimately, I would love to not have to hide and de-activate tracks in fear of maxing out my CPU, but if this is the worst of my problems -- then I'm in good shape! (Great workaround by the way. Thanks again spkguitar!)
And just out of curiosity... is there a PC out there that can handle multiple instances of CPU-heavy plugins such as amp sims (with impulses) and large Kontakt libraries simultaneously without breaking a sweat? Very curious.
Old 08-21-2009, 01:21 PM
Jon E. Jon E. is offline
Let me add my variant to spkguitar's method. I use just one guitar track to record the dry guitar and monitoring with the amp sim plug in on the track. I save the amp sim settings (often multiple settings) to the session folder. When I'm through recording I duplicate the track to a new playlist(s) and apply the AudioSuite version of the amp sim using one of or several of the settings files in the session folder. It's a little easier than setting up and routing together two tracks and much faster than bouncing to disk.
EDITED: My bad, I realize my method is exactly the same as Wango's except my processed track replaces the dry track, I thought he was bouncing, not using the AudioSuite plug.
HD Native on Win7 - 9094 & 9129 errors stardancer Pro Tools HDX & HD Native Systems (Win) 17 02-08-2012 10:39 AM
Help w/(9129),(9094) errors joewilly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-07-2006 08:53 PM
9136, 9094 & 9129 errors, RAM issue? bluerockgod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-03-2005 01:23 AM
have digi -001/new sys, get 9129 9094 errors RFwarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-25-2003 04:19 PM
9129 and 9094 errors KdC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-30-2000 10:34 AM
