Editing a Midi program sound.... disabling vibrato on the Pitch Bend Bar
Thanks for any help...here's the scenario...
My sound module has 2 separate effects possible per Program sound(piano, guitar, whatever...). I have one effect Disabled, and am dealing with just ONE effect, right? Now, on the pitch bend bar, it can be programmed to be a WahWah when pushed forward. OR it can be vibrato. I want straight Wah ONLY(which I've set it up to do), and no vibrato, but the vibrato won't go away. Do any of you know where I might possibly disable vibrato, given that many Midi devices are similar in this type of setup?..... So to sum up, I've got one effect (distortion) on this Program, the Pitch Bend is set to Wah, but it also triggers Vibrato, which I DON'T want. How do I disable Vibrato? Thanks, Roy
rh music |
Re: Editing a Midi program sound.... disabling vibrato on the Pitch Bend Bar
maybe it isnt possible to disable vibrato....but you could try to edit the vibrato parameters. Change the amplitude to zero, so although it will do a vibrato, it will detune by zero....
I also think this stuff needs to be edited on your sound-device, and not within ptle...
What's that? - That's the machine that goes "pling". Bastiaan |
Thanks Bastiaan...
I am indeed exploring within the Device, and not PT. It MAY be, that it is programmed in with each sound, because I see nothing to set Vibrato parameters. Yet, one program has WAH and no vibrato when pushing the Pitch Bend forward, while another (the sound I want) has BOTH Wah and Vibrato. I may have to give up on getting it MY way... [img]images/icons/wink.gif[/img]
rh music |
just a silly thing......did you check the manual. Some of those are pretty unreadable, i know, but it should be in there. Maybe you can find something that will point your nose in the right direction. I am willing to do some research if you can tell me a bit more of your sound-device...
Thank you Bastiaan,
I have no manual for this device, because when I bought it, all they had left was the demo (so I got it a bit cheaper). They 'couldn't find' the manual. But, it's a Korg 01R/W Sound Module (there's a keyboard model with a slightly different Model #, but same thing). Thanks, Roy
rh music |
Roy,
I found the quickstartguide, and for what i can see, you have 2 independent effect in the box. I suggest you copy your program to a user-instrument, and try to remove the vibrato effect. Maybe that's also to be found in an LFO-menu... I hope i make sense... Faq's Quickguide
Thank you very much, Bastiaan...
Let me ask you, when you say "copy your program to a user-instrument", do you mean to copy it to a totally separate Midi device, or just to another program within the Korg itself? -Roy p.s. Thanks for the links!
rh music |
within the korg. Usualy you have banks with preprogrammed sounds and settings that cant be altered. And you have banks of sounds that you can later. Start by copying the sound you want to such a userbank, and then you can access and change the settings. Maybe the korg doesnt work like that...
In the manual (quickstart) i saw you have 2 effect processors. I think one of them is providing the vibrato, and the other is providing the whawha. So maybe you can simply turn of the vibrato, or set the amplitude to zero... Good luck!
But....did you get it working the way you want?
Edit pitch bend midi data | bwandon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-24-2018 08:20 PM |
Pro Tools LE 8 Midi Pitch Bend Problem | W Sound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-09-2011 02:09 PM |
MIDI track not reading pitch bend data? | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-11-2009 07:04 PM |
MIDI Pitch bend question, please? | William 2014 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-30-2006 11:53 AM |
MIDI : Pitch Bend | Muxlow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-01-2003 09:28 PM |
