Old 07-30-2010, 08:40 AM
dawsonaudio dawsonaudio is offline
Default Constant DAE-9073 (OSX/PT6.4.1 upgrade from OS9.x/5.x)
I decided to install OSX 10.3.9/Quicktime 6.5.2/PT 6.4.1 and have been getting continued dae 9073 errors. I trashed all of the digi preferences, increased h/w buffer, allocated more memory...etc..., but the error still keeps happening.
I didn't have any issues prior with the exact same hardware setup I have with the old OS9.x and PT5.x that I had on this computer.
Are there things I need to do differently with the new OSX? I don't have anything else running on the system other than the factory PT install and software that came with the new OS.
My external drives are 10,000rpm and are connected with an Adaptec u320 card. All drives have been running fine.
To test, I created a new session, imported one stereo track and after duplicating it 8 times, the dae error came up. 4 stereo tracks running at the same time weren't a problem. All audio data is coming from same/one hard drive.
Thank you,
Nate Dawson
Old 07-30-2010, 09:46 AM
Default Re: Constant DAE-9073 (OSX/PT6.4.1 upgrade from OS9.x/5.x)
Maybe someone has the same OS and PT system that could give me some configuration tips here.
Thank you,
Nate
Old 07-30-2010, 10:29 AM
FajitaTone FajitaTone is offline
do you have the OSX drivers for that SCSI card? did you install them as "root" user?
Ray Trujillo
Freelance Audio Engineer
Old 07-30-2010, 10:40 AM
Didn't know I needed to upgrade those. I'll look for the upgrade at Adaptec.
Thanks,Nate
Old 07-30-2010, 11:16 AM
That worked. Thank you for your help.
Nate
constant error '-9129' after 9.0.3 upgrade gthrasher Windows 0 07-11-2011 12:37 PM
Constant -9073 error....please help! rah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-13-2011 08:18 PM
ProTools HD|7 constant DAE-9073 errors after 5 min Mixchump Pro Tools TDM Systems (Mac) 8 12-21-2005 09:12 AM
Help!! Constant 9073 errors...aaaggghhh! Allbaldo Pro Tools TDM Systems (Mac) 8 04-11-2004 09:51 PM
Particular session brings constant -9073 error... arecee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-30-2002 08:31 AM
