Old 05-06-2019, 04:59 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Pro tools | control just stopped working
Mid 2012 mbp OS X 10.13.6 pt 2018.12 older iPad with compatible versions. I can’t remember the details now and have since gone down a rabbit hole of which no return is likely not possible.
Here’s the story. Everything was working tickity boo. No problems for over a year. Changed nothing, left on a course for a week. Came back and it hasn’t worked since. The iPad mini isn’t capable of updating past 9.3.
Tried rebooting, both. Over three days, tried starting and stopping eucon. Tried quitting and restarting. Tried re-installing eucon. Confirmed that eucon is enabled. Tried disabling/enabling wifi on both.
Tried on OS X 10.13.4 w/ pt2018.10with same eucon configuration. Tried updating the pro tools control app. Now I’m out Of thoughts and running low on patience.
I know this app is free but I’m baffled at the fact that it just went from working to not working when I was a week away from my machine. I’m assuming some ghost came and tried to do some tracking.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 05-08-2019, 06:43 AM
EddieJones's Avatar
Default Re: Pro tools | control just stopped working
You don't say what version of EuControl or iPad Control App ?
Old 05-08-2019, 06:47 AM
dr_daw's Avatar
Now I’m locked on 18.3 and the recent version. I backed up my iPad prior to changing anything. But for some reason I can’t restore it. Still the same result. But read that 18.3 requires iOS 12. My iPad is so old that I can’t update past 9.3. So that is the end of pro tools control for me. Unless someone has the apk file for 3.7. But I already had that, and it just stopped working.
Across multiple installs of OS and pro tools of which it worked a week ago.
Rig
Old 05-08-2019, 06:56 AM
EddieJones's Avatar
The versions have to match to work. Have you tried to download the latest iPad Control App. It's not supported on that OS but it might still work.
Old 05-08-2019, 06:58 AM
dr_daw's Avatar
I have and it’s the same result. I would love to try the 3.7 version again on my iPad, but Apple doesn’t allow rolling back on apps. I’ve looked to see if I can find the app, but no luck.
At this point I’m guessing my years of using pro tools control are gone. It was a good two year run.
Rig
Old 05-08-2019, 07:05 AM
EddieJones's Avatar
So the latest iPad Control App installed on the iPad and runs...but won't connect?
Old 05-08-2019, 07:56 AM
dr_daw's Avatar
That’s correct
Rig
Old 05-08-2019, 08:15 AM
EddieJones's Avatar
That's great...as I think you will be able to get it to work. Can you tell me the IP address of the iPad (settings, WiFI, click on the i next to the network you are connected to), and the IP address of the WiFi adapter on the Mac (prefs, network)
Old 05-08-2019, 12:06 PM
dr_daw's Avatar
I can try to do that when I get home. At work now. But I appreciate your help
Rig
Old 05-08-2019, 05:08 PM
dr_daw's Avatar
On the Mac 192.168.1.74 on the iPad 192.168.1.66. So they’re definitely connected to the same router.
Rig
Control + Shift Snap to stopped working Wildkat666 General Discussion 0 08-13-2018 08:37 AM
Artist Control Softkeys stopped working on Ableton Feinbeat Artist Series 7 09-24-2017 03:37 AM
Video Window just stopped opening + Crossfades stopped working [SOLVED] DBK macOS 0 02-28-2015 12:34 AM
PRO TOOLS 8LE was working on windows 8, stopped working after 8.1 update... Jon Vandenbor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-01-2015 02:10 PM
vegas mode stopped working on D-Control tomcat ICON & C|24 3 11-01-2007 11:15 PM
