Crashes with audiosuite P.I.
I have my doubts about the stability of Protools 6.2.2 under Panther 10.3.2. Ik keep having strange crashes without warnings. Crashes on opening a new session, crashes when I want to apply an audiosuite plugin, crashes when adjusting Plugin parameters. I run Protools HD on a new G5 double pr.with a control 24. Anybody have suggestions, anwers. Thanks guys (and girls, if so).
Re: Crashes with audiosuite P.I.
Sounds like you may have some plug-ins that haven't had a PACE update. Please refer to the following, from the ReadMe and the compato page http://www.digidesign.com/compato/osx/g5/
Warning: Updating Pace-Wrapped Plug-Ins Due to a recently discovered PACE copy protection bug, some users may experience instability and/or crashes when launching Pro Tools, opening a session, or dismissing a trial-period dialog if any Pace-wrapped third party plug-ins are installed. The fix for this bug is in the latest PACE drivers included and installed automatically within the Pro Tools software installer. Updates to all plug-ins are also necessary to prevent instability and/or crashes. All plug-ins supplied with the Pro Tools 6.2.2 installer have been fixed. To determine which plug-ins are affected, we have included a utility which will scan your Plug-Ins folder and list all plug-ins that need to be updated. To use this utility, just launch the "Digidesign Plug-In Validator" application located in your Pro Tools Utilities folder. If any of your non-Digidesign plug-ins have not been updated, they will be listed in the display window. Please visit the Web site for the manufacturer of any affected plug-ins and download the update (if available), or ask the manufacturer when one will be available. Even if you do not have updates for all your plug-ins, instability will only occur immediately after adding or removing a plug-in from your Pro Tools Plug-Ins folder. After the first crash and subsequent reboot, you should not see any further problems, unless you then add or remove plug-ins from the Plug-Ins folder. dc |
Re: continuing audiosuite crashes
I have the same problem with audiosuite, both with 6.2.2. and now 6.2.3, and all of my plugs ARE up-to-date.. (brand new HD3 Accel/dual G5 2ghz,1.5 gigs ram). It seems worse than it ever was under OS9---back then I was only having 2 or 3 crashes per day; now it's more like 6 or 7. Almost always, audiosuite is the culprit, whether I'm previewing, processing, or simply selecting a plug. Some plugs are worse than others---Speed and GRM tools are particularly bad. I was really hoping they'd get around to fixing these issues under OS X. Almost every PT user I know has had these same audiosuite crashes for years. At least they don't typically lock up your whole machine.
I also sometimes get an extremely annoying message, usually when trying to use audiosuite gain or pitch: "This plug-in will only process 48 channels at a time..etc" or some crap. Anybody have any magical solutions to the constant audiosuite crashes? -ec |
Audiosuite crashes on launch | dasistwas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-07-2006 10:14 AM |
Audiosuite Crashes - PT LE 5.2 | Rich Walsh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-06-2004 05:05 PM |
AudioSuite crashes Logic 6.1 in OSX | Lee Blaske | Pro Tools TDM Systems (Mac) | 1 | 09-06-2003 09:31 AM |
5.1.1 Audiosuite crashes | ekuehnl | Pro Tools TDM Systems (Mac) | 0 | 07-03-2001 10:10 AM |
Audiosuite Errors/crashes | kchurko | Pro Tools TDM Systems (Mac) | 3 | 03-22-2001 02:45 AM |
