Old 10-22-2019, 11:12 AM
belasoul belasoul is offline
Default Diegetic Sounds TV/Radio Filter
What's your favorite tool/chain for diegetic TV/Radio sounds in the room.
What kind of simulation do you recommend? Either from Avid or third party plug ins.
Béla Brandes | www.bbsounddesign.de
Old 10-22-2019, 11:23 AM
reichman's Avatar
reichman reichman is offline
Default Re: Diegetic Sounds TV/Radio Filter
Speakerphone and Altiverb in series are pretty powerful. I've had great results with that classic combo.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 10-22-2019, 11:41 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Speakerphone is unreliable re automation, so I tend to use McDSP Futzbox. Speakerphone also sounds “too real” and can loose intelligibility, so McDSP scores there too.
I tend to like Cargo Cult’s Slapper before any reverb, it adds some complex delay which makes you use less reverb and the reverb matching therefore becomes less critical. Which makes it all easier to sell to the viewer.
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 10-22-2019, 01:47 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Originally Posted by MIKEROPHONICS View Post
Speakerphone is unreliable re automation...
Its not the automation its one of the most stupid thing in Speakerphone:
Many presets have Auto Gain engaged along with the input trim pot.
You need to turn off the Auto Gain and set In gain to zero each time you write the automation for selection.
For some reason Auto On/Off is not automation enabled.
I wrote to Aram several times regarding this issue but he refuses to change it (quote him):
the auto level is in the plug-in is due to the sample bay (the noise generating part of the plug-in).
Many presets rely on the sample bay content. The right mix between input audio and sample bay content is important to make the presets work.
This is why the auto level is engaged on most presets.
Once turned off the auto level should not turn ON again and the input level will stay untouched.
However when you load a new preset (containing an auto level ON setting) the auto level will be set to ON again.
I recommend you to save the preset you use with auto level OFF. Then when you use this presets and write to all enabled, you should not get any odd behavior.
Odd behavior can for instance start when a Speakerphone setting (with auto level ON) is saved in the session. Then this will reload on recalling the session.
The bottom line, other than this issue I find no automation issues in Speakerphone and I use it in very complex feature sessions. Pay attention to turn off AutoGain each time you load the preset and you will be fine.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 10-22-2019, 02:28 PM
That’s good to know thanks
cheers
BAFTA member
IPS member
Old 10-22-2019, 08:46 PM
Henchman Henchman is offline
I use audiothings "Speaker".
$20
And Acon Digital reverb
www.markhensley.tv
IMDB Credit List
Living the dream.
Old 10-22-2019, 11:11 PM
Led Led is offline
If you ever come across one cheap, PCM81, a patch called "In Living Room", my go to and I just print it back into PT
HTML code is On
During recording, audio sounds fine, during playback, it sounds bit crushed JJTaylor Pro Tools 11 16 03-08-2017 05:05 AM
Structure FREE Sounds 14 - 4 Cool Bass Sounds RussUK Pro Tools M-Powered (Win) 0 02-18-2009 06:53 PM
Pro Tools For Radio Production, Adobe Audition And Google Radio Automation... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-09-2008 07:51 PM
Any good Filter / Step Filter Plug-ins? Jsswtpmp182 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-07-2006 05:01 PM
Best radio automation program for professional radio stations? GuitarEasley General Discussion 22 03-23-2002 11:32 AM
