Old 09-25-2010, 10:12 AM
CliffT CliffT is offline
Default Eleven Rack Keeps Disconnecting
Just Got the Eleven Rack and I am floored by how awesome it is. It's exactly what I've been looking for and it sounds frickin' awesome. Makes we want to play guitar all day again.
But...
The damn thing keeps disconnecting.
If I'm in Pro Tools I can work for about 1/2 and hour before I get the message:
"Pro Tools cannot communicate with Eleven rack."
Once that happens I have to shut down the whole system and restart.
If I'm in Ableton Live or Reason or just listening to music in iTunes the same thing happens, just without an error message. In those cases I just power down the 11R, restart it and it's working again.
I've updated the firmware. I've disconnected all external USB stuff (hard drives, MIDI controller, printer). I've tried different USB ports.
Update: This seems to happen every time I step away from Pro Tools, leaving the system idle for a few minutes. In other DAWs it seems to happen randomly.
System: iMac 2.66 GHz Core Duo/4GB RAM
Leopard 10.5.8
PTLE 8.0.1
Old 09-26-2010, 05:42 PM
TheChimp's Avatar
TheChimp TheChimp is offline
Default Re: Eleven Rack Keeps Disconnecting
Is there a reason you haven't upgraded to Pro Tools 8.0.3cs2 or 8.0.4? Doing so might be helpful.
_______________________________
The Chimp
Delivery Manager/CSM, Guitar Products/AAX Plug-ins
P&S Creative Professional
AVID
Old 09-27-2010, 03:26 AM
TFord TFord is offline
I had a bad USB cable with my 11R. Did you try a other USB cable?
Old 09-29-2010, 02:11 PM
Benoni's Avatar
Benoni Benoni is offline
I just want to add, while I dont get disconnected after a successful launch.
I have found that the times the 11R window doesn't launch, the MIDI OUT 1 light on my 003R blinks while launching a session after I boot up PT and the 11R window is trying to connect.
For me, after booting the PC, I have to let it sit idle for about 10 minutes before I can launch PT or the 11R window will not launch and the MIDI OUT light on the 003R blinks while PT is trying to connect to the 11R window. Even If i click YES re-connect, the MIDI OUT 1 light blinks, and I get the same error message (Would you like to re-connect ect..)
So I have to shut down PT and re-launch, and sometime I have to totally re-start the PC and launch PT.
When It does connect, no MIDI lights blink on the 003R, and the 11R window launches fine.
Again, i run the 003R as my main interface with the 11R patched in via SPDIF. Just a fyi.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Differences Between Eleven Rack & Eleven Plugin Becharax Eleven Rack 15 10-16-2015 06:07 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Some experimental tracks using Eleven rack and Eleven RTAS kittybite Eleven Rack 4 06-18-2013 12:18 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
