Old 10-29-2009, 09:04 PM
paulrgmusic paulrgmusic is offline
Default Re: The Official Unofficial Windows 7 Thread
An update:
So far I have installed:Strike, Structure LE, Transfuser, Ozone 4, Spectron, iZotope RZ, Hybrid and iZotope Vinyl.
All working perfectly (touches every bit of wood in sight)! Now if only M-Audio would get a driver for the Axiom Pro out...
Problem is...it's now 4am
Benoni - I have a USB Mbox 2 Mini.
I'll work on putting some info later. Right now it's bed for me!
Night all
Paul
Old 10-30-2009, 05:12 PM
jazzmandan jazzmandan is offline
Originally Posted by fredto1 View Post
So I just upgraded my OS from Windows Vista Home Premium to Windows 7 Home Premium and I also am using Pro Tools LE 7.4cs10 with my Mbox Mini. Upgrade went well and all of my programs are working great except for PT. I've been looking around but not finding anything on my issue.
ISSUE: I've clicked and right clicked "run as admin" but the same thing happens, it does something for a while and then PT never actually opens. I've pulled up the "Task Manager" and under the "Processes" TAB, it shows PT running but under the "Applications" TAB there is no sign of it.
When I keep opening it from the icon on the desktop or from the icon in the "Program Folder", a new protools.exe pulls up under the Processes TAB, Ive hit the icon 5 times and there are 5 protools.exe in the Processes TAB.
I am pulling my hair out here....is there anyone with the same issue or some answers to this??
Please Help!
Fredto1, could this be a IE8 issue??
~2004 - Dell 4600 P4 3.0GHz, 2.0 GB Ram, XP Home SP3, 80GB HD for System, 120GB HD for Audio BIAB 2009, Pro Tools 8.0, MBox
09/12/2009 - Dell XPS 435T/9000 i7, 6G Ram, Vista 64 Bit 750 G SATA for System, 1TB SATA for Audio, Protools 8.0.1, MBox
10/31/2009 - Win 7 64Bit
MBox /PT not supported under Win7 - I didn't leave PT, PT left me!
11/30/2009 - MBox, REAPER
http://www.jazzmandan.com
Old 10-30-2009, 06:41 PM
Naga Naga is offline
Originally Posted by Benoni View Post
A few people are having problem loading PT on Windows 7. So here is a Video. If you have a firewire interface be sure to do the Legacy Driver FIRST. Then move on to this video.
PT LE 8 Windows 7
Agh, that kinda sucks but I appreciate the info. Now the question is can I just uninstall pro tools and re-start or do I have to do a fresh install of Win7?
Hoping for the later but if I gotta do the whole thing again to get it working I will.
Thanks.
Old 10-30-2009, 07:13 PM
dzilizzi dzilizzi is offline
Just a thought. I have Vista and PT 7.4 was running great. During one of my Windows upgrades, I loaded IE8. I then had the same problem you are having. Took a while to figure out what had happened. Removed IE8 and PT is back to working fine. I have to keep unchecking IE8 everytime Windows tries to update it.
Old 10-30-2009, 08:39 PM
Greg M Greg M is offline
Just a quick question about Win7 32bit. What is the incentive to run this OS right now if you have WinXP or Vista running fine? I can see tweaking around with Win 7 64 bit but the rest of the world doesn't really seem fully ready for it yet. I have Win 7 Pro 64bit on another drive that I swap into my PC when I want to try something out, but I'm basically learning the interface as it's a bit different than WinXP.
I looked at the MS Compatibility page and found that there seems to be pretty good hardware support for 64 bit drivers, however, even though most software is compatible it is 32 bit so it runs under x86. To me, the big deal is getting Win 7 64 bit with 64 bit hardware and software going.
BTW, you can probably stop right clicking to run things as Administrator if you find the xxxx.exe file you are trying to run and change it's security properties to allow anyone to run it (put a check mark in all of the permissions boxes). You may also need to do this to your session files.
I would also comment that anyone getting a new computer with Win 7 should be sure to get it with one of the Win 7 versions that support XP Mode (Pro or Ultimate). All of the hardware on new computers should support the virtual attributes necessary to run things in XP Mode.
As mentioned in as earlier post, please specify somewhere in your post whether you are running 32 or 64 bit Win 7 and whether your audio interface is USB or Firewire. These two points are paramount.
Can anyone answer my original question?
Thanks,
Greg
Protools PC, i9 10990, Gigabyte X299 mobo, 64 GB ram, EVGA Nvidea GT 720 TI video card, Win 10 Pro, PT Ultimate (Native) 2024.3.1, HD Omni, HD I/O 16x16 .
  #16
Old 10-31-2009, 02:22 AM
So you have Windows 7 installed right? And Pro Tools? Is PT not working? Did you do a fresh install of 7 or an upgrade?
Yup Win7 64 Bit, fresh install.
I don't mind reinstalling the OS, nothing much on here but PT anyway.
  #17
Old 10-31-2009, 02:49 AM
MrBlack MrBlack is offline
Run as Admin is not an access violation thing, its a way to run in the hidden Admin acccount so you have more bandwidth ...
More bandwidth ?
003R - PT 11.0.3 - MAC Mini - SSD for OS & 2nd Internal Hard Drive for Recording - 16GB RAM
  #18
Old 10-31-2009, 05:18 AM
Talking Re: The Official Unofficial Windows 7 Thread
Hi all
An update, as promised.
I have Win 7 (64) installed. PT8cs3 is working really nicely with all of the stock plugs and VIs.
I have also successfully installed Strike, Hybrid, Transfuser, Structure LE, RealStrat, Ozone 4, iZotope RX, Spectron and Melodyne Plugin.
Things that have not worked are Miroslav Philharmonik (7401 errors) and M-Tron Pro (Access Violation Errors). I'm not really that worried about these as they have had very limited use and I am sure that they will be sorted in the fullness of time.
My biggest disappointment is with m-audio. They have released public betas for most of their gear but still nothing for my Axiom Pro . In fact this won't even function as a basic keyboard so I'm going to have to grab my old Novation ReMOTE SL until drivers are released for the Axiom Pro.
So...even though I haven't had 100% sucess, I am really delighted. Just as a side issue - I haven't disabled anything (WiFi, Aero, Slideshow Wallpaper) and I have also played around with several other apps running too.
My System is:
Win 7 Home Premium (64)
Core 2 Quad (6600 @ 2.4ghz)
4GB Ram
2x500GB HDD
MBOX2 Mini (USB)
All Software paid for & legal
Good luck to all of the others on here trying out Windows 7!
Paul
  #19
Old 10-31-2009, 08:31 AM
Everything that is hooked to your mobo uses bandwidth, and you only have so much depending on several things. hard drives, USBs, PcIs, firewire all use bandwidth. If you add too many things, first it starts to drop or interrupt USB devices, then you may have a crash or lose contact with other things hooked up to your PC. Run As Admin helps to eliminate or at least severly reduce those errors.
I'm sorry but that is nonsense.
Running as Admin has nothing to do with hardware interrupts or the bus speed on the motherboard.
mmm..seems like I have been picking on your posts! Honestly its not intended,
I have a composition due in on Monday and I'm just diverging...
  #20
Old 10-31-2009, 01:51 PM
M-ManLA's Avatar
M-ManLA M-ManLA is offline
I hear yeah man Its time for sleep.
Its seems that the USB interfaces will run on 64bit since the drivers are more universal then firewire.
Has anyone got a Firewire interface running with 64 bit?
Is IE8 causeing you any problems? I see you have Hybrid and thats a plug that has known issues with IE8. I have never had any IE8 related trouble with any of my partitions.
I have it running on 64Bit. I have a 003R running Windows 7 Ultimate 64bit. I have Pro Tools 8.01 installed. It blue screened when I just had 8.0, so make sure you update it.
www.M-ManLA.com
www.facebook.com/MManLA
www.soundcloud.com/m-manla
Pro Tools 12, Sibelius First 7/Presonus Studio 192/Windows 10 Pro
THE UNOFFICIAL "DAVE C" TEST RESULT THREAD scuzzytim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 79 07-14-2010 08:21 PM
The unofficial PTLE bottom-feeder thread! M.Brane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 07-18-2006 06:07 PM
unofficial "Problems with PT7" thread nikki-k Pro Tools TDM Systems (Win) 68 05-02-2006 01:00 PM
---unofficial BTD report only thread--- nikki-k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 59 12-02-2003 04:29 PM
