  #21
Old 10-15-2008, 07:12 PM
HeySchlitz HeySchlitz is offline
Default Re: Play/Pause issue driving me nuts...
Well in a strange turn of events...my motherboard died (1 day after the Fry's return day...great). I have a P5K arriving tomorrow with the p35 chipset. I'll try the same steps with the new motherboard and see if that changes anything.
  #22
Old 10-16-2008, 02:01 AM
mano111 mano111 is offline
Good news.
Problem has started getting worse, happening at all buffer sizes, and even when auditioning from the Import audio or workspace so I ended up ... deleting preferencaes and databases using tech support tool. This seems to help alot.
It still happens on 64 and 128 buffer size every now and then, but much less than before, and its fine in 256 and up...
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
  #23
Old 10-16-2008, 12:15 PM
GTBannah GTBannah is offline
Originally Posted by AlexLakis View Post
I dunno what else to tell you other than the fact that your minimum H/W Buffer Size is 64...
You're making me nervous now.
I just went: Setup-> Playback Engine-> H/W Buffer Size anthere are five options:-
128, 256, 512, 1024, 2048.
What am I missing? Do I have to set this up before starting the project?
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
  #24
Old 10-16-2008, 12:35 PM
daeron80 daeron80 is offline
64 Buffer is only avail in 44.1 and 48 kHz sessions. In 88.1 or 96 kHz sessions, all Buffer sizes are double.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
  #25
Old 10-16-2008, 12:36 PM
I now have to find a way to glue my hair back on.
Thanx, man.
Derrkins
GuyBarTola
  #26
Old 10-16-2008, 02:38 PM
original_min original_min is offline
I get same problem now and then.
Nvidea QuattroFX card or Asus 7300 (Nvidea) card, same result on both.
Haven't tried removing graphics driver yet.
I think it happens more often at low buffer sizes, and without FX inserts.
Delete prefs and databases not fixing it.
002R, Q6600, 4gb, separate drives etc'
  #27
Old 10-20-2008, 09:42 PM
Hmm....well I tried a p5k but audio dropped out at 64ms latency. Not sure what that was about but I went with a new P5QC instead. Completely reinstalled everything....started fresh project (no audio, no midi) hit the spacebar and this bug still occurs.
Any ideas?
  #28
Old 10-21-2008, 03:32 AM
Thanx, man.
.... meaning, this project is set for 88.2 audio.
Sorry if it wasn't clear before.
Derrkins
GuyBarTola
  #29
Old 10-21-2008, 06:09 AM
Dude, I've glued my hair back on so many times, I look like Frankenstein.
David J. Finnamore
  #30
Old 10-21-2008, 08:40 AM
DigiTechSupt's Avatar
Any ideas?
When you removed the plug-ins previously, did you also trash preferences?
Can you post a list of installed plug-ins, using the Tech Support Utility?
Avid Audio Tech Support
Support FAQ
Pro Tools 11 Play-Pause Issue ProdGawd Windows 7 12-12-2013 05:22 PM
PLAY / PAUSE - Issue ... Once More !!! Zergei Pro Tools M-Powered (Win) 2 12-27-2009 11:50 AM
Some info on the Play Pause Issue Fastermouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-31-2009 05:18 PM
Play/Pause Issue Resolved - Maybe? Try This. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 167 06-20-2009 08:42 PM
cursor issue driving me nuts!! stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-12-2006 03:21 AM
