Region Replace
Anyone know the new shortcut for region replace in 6.9? it used to be command click!
Re: Region Replace
There are 3 buttons that you should look at. Go to your Pro Tools Preferences. Click the Editing tab. At the bottom in "Matching Start Time" Takes List... The first option will allow you to replace the file if the names are the same. The second option will allow you to replace just that selected region and not the whole region (good for cutting tracks and selecting between them), and the third works with the 2nd, like this... your regions are stacked like waffles. Let's say you have 5 waffles, you cut right down the middle of them. You want the 3rd waffle on the top of the left side and the 4th waffle on the top of the right side. If the 2nd 2 options are selected, you can do that.
Mmmm, waffles...
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Re: Region Replace
Thanks, i do know that part but it was more the short cut for replacing regions with ones from region list, it used to be command drag the region but with the new selection shortcuts in 6.9 it has changed!!
Re: Region Replace
Sorted, Command/shift and drag..
Re: Region Replace
Ohhhh! That's what you meant, thanks for the answer too! I still like waffles though...
Replace Region BUG | naughty G | Pro Tools TDM Systems (Mac) | 1 | 05-13-2009 04:50 PM |
Replace region command in PT 7.1 | fman | Pro Tools TDM Systems (Mac) | 1 | 05-30-2006 09:45 AM |
Using Replace Region — need expert | Dan Pinder | Tips & Tricks | 9 | 12-16-2005 11:01 PM |
6.9 Mac Replace Region Bug?? | Borg | Pro Tools TDM Systems (Mac) | 7 | 07-05-2005 08:17 PM |
Replace all instances of a region | d_matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-15-2003 11:30 AM |
