Old 05-09-2005, 03:16 PM
Borg Borg is offline
Default 6.9 Mac Replace Region Bug??
3 HD systems, two Macs, one XP.
Command + Drag (a region from Audio Regions List) on a Mac doesn't work on both systems.
Works fine on XP.
Anyone else experiencing this??
- Borg
10.3.8 - G5 Dual 2G - HD2 - Sync - 192 - Mojo - ProControl
www.foxmountain.com
@FoxMtnStudio
Old 05-09-2005, 04:11 PM
Default Re: 6.9 Mac Replace Region Bug??
What do you expect it to do? Perhaps you want to use Control+drag to snap the regions to the timeline location (equivalent to Start+drag in XP)?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 05-10-2005, 06:49 AM
Rail,
Check out the Pro Tools Reference Guide, Chapter 18: Advanced Editing.
"...you can use the Replace Region function to replace multiple instances of an audio region in a playlist with another region that you Command + drag from the Regions list..."
That should bring up the Replace Region Dialog box (using Cmd + Drag on a Mac).
It doesn't work with 6.9 on a Mac. However, on XP, with the Windows keyboard shortcut equivalent (Control + Drag) it works fine.
make sense or am I missing something??
- Borg
www.foxmountain.com
@FoxMtnStudio
Old 05-10-2005, 09:25 AM
blairl blairl is offline
You're right. I can't get it to work either in 6.9 on a Mac.
Old 05-10-2005, 12:31 PM
DigiTechSupt's Avatar
Beginning in 6.9, the key command for Replace Region is now Command-Shift-Drag (Mac) and Control-Shift-Drag (Win). We'll get this updated in the next rev. of the manual.
-Jordan
Avid Audio Tech Support
Support FAQ
Old 05-10-2005, 04:23 PM
Thanks Jordan.
- Borg
www.foxmountain.com
@FoxMtnStudio
Old 07-05-2005, 11:50 AM
ADB ADB is offline
-Jordan
It seems like this new key command has a slight conflict with the "Region List Follows Track Selection" preference. When this preference is selected, using the command-shift keys will cause all the regions in the region list between the "to-be-replaced" region and the "replacement" region to be highlighted. Is this as designed, or a bug? The feature stll works, but visually it is a bit confusing.
ADB
Old 07-05-2005, 08:17 PM
Danny Caccavo Danny Caccavo is offline
-Jordan
ADB
We apologize, yes, it's confusing. Although it highlights the "inbetween" regions, the one you actually click on will be the one you replace the current region with. This bug will be fixed in the next major release of Pro Tools.
Danny Caccavo
Product Manager
Digidesign
Replace Region BUG naughty G Pro Tools TDM Systems (Mac) 1 05-13-2009 04:50 PM
Replace region command in PT 7.1 fman Pro Tools TDM Systems (Mac) 1 05-30-2006 09:45 AM
Using Replace Region — need expert Dan Pinder Tips & Tricks 9 12-16-2005 11:01 PM
Region Replace webby Tips & Tricks 4 06-09-2005 09:44 PM
Replace all instances of a region d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-15-2003 11:30 AM
