Old 12-31-2005, 01:26 PM
xmlc13v xmlc13v is offline
Default Spontaneous reboots after Pro Tools installation
I have a new HP Pavilion with an AMD Athlon (tm) 64 X 2 dual core processor/XP Pro Media Center OS. After installing ProTools LE version 6.7 r2 with a Mbox and restarting the system it goes into a reboot loop, over and over again. It gets to the welcome screen, but then just starts to boot again and again. The only way to recover from it is to do a full system recovery from the boot screen. Solutions on the DigiDesign site say that new Interlok drivers will correct this problem. It does not. I can not get booted up to the desktop after the install. I downloaded the new Interlok drivers and installed them first, but still no success. I used the configurations suggested in the install manual. I also turned off the DEP (Data Execution Prevention) feature for all but Windows services that was also suggested. The compatibility documents say my system should be compatible, but something is causing this spontaneous reboot after install. What can I do to get the software installed and get booted up, without going into this reboot loop?
Old 12-31-2005, 04:08 PM
100grit 100grit is offline
Default Re: Spontaneous reboots after Pro Tools installati
Do you get any error message?
Old 12-31-2005, 09:21 PM
No error messages at all. Just a reboot loop when trying to restart.
Old 01-01-2006, 08:16 AM
msg6794 msg6794 is offline
i had the same problem, and it was fixed by installing 7 instead of 6.9 for me. 6.9 wouldn't work; 7 works quite well. it's well worth it, since 7 is optimized for the dualcore anyway.
003 Rack | Dell Studio XPS 8700 (Core i7 4790, 16GB RAM) | Windows 10 64-bit / PT 12.6
Old 01-01-2006, 06:53 PM
I'll give it a try. Thx
spontaneous shutdown pro tools 8 parlour snake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-13-2010 06:33 PM
Pro Tools 5.1 LE reboots PC over and over......... kpMiamiHurricanes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-28-2003 12:50 AM
Spontaneous reboots with 6.1 and dual monitors Joe Evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-24-2003 12:08 AM
Spontaneous Reboots and Access Violations... HELP!!! 2Sick_Music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-24-2003 11:38 PM
Spontaneous Reboots, very reproducible ThreeBoyz Digidesign Hardware & Software 0 10-16-2002 09:14 PM
