setting external drive record
I am trying to use my external drive to record to in tools, I have to tried to set this drive to record in pro tools HD and M-powered and it says that it can not be designated as an audio record volume because it is not a valid audio volume. How can I get pro tools to see this hard drive as a record volume. It is a Iomega portable 160gb usb/firewire harddrive.
Re: setting external drive record
what is the drive speed? Is it bus powered?
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
the speed is 5400 rpm and yes it is bus powered by firewire, I only use it with firewire
thats your problem. The drive is too slow for Pro Tools. Pro Tools requires at least a 7200rpm drive.
And, bus powered drives aren't the greatest for recording. I've never had much luck with them for anything other than transfer/portable drives. http://www.digidesign.com/index.cfm?...4&itemid=23126
I can record to my macbook's internal hard drive and I"m sure its 5400, or does pro tools see the internal differently? So USB is better for recording than firewire?
you can record to an internal drive, but it is not recommended and you wouldn't be able to get the track count and performance you could get out of an external firewire HD. It can also lead to errors and crashes.
Hard Drive requirements - all types. http://www.digidesign.com/index.cfm?...4&itemid=23140 USB is not recommended at all. USB 2.0 Hard Drives USB hard drives are NOT recommended or supported for use as recording drives. Limited testing has shown that performance with USB drives is inferior to that of FireWire drives.
thats what I thought, since you said firewire wasn't I thought you were suggesting to go with USB.
I figured out why I couldn't record to the drive, it was not formatted for mac. I thought I had done this before but I geuss I didn't, when I checked it was formatted to fat32 |
Secondly, bus powered drives are only a potential issue if your hardware has under-specified bus power capabilities. Some early Macbook Pro's had rather keen protection on their Firewire bus power which led to power being shut off as a protection before reaching the usual limits. None of this is a Protools issue. If a drive is inaccessible for recording, go to Workspace and check that the drive(s) has an 'R' in it's 'A' column. |
Setting up External Hard Drive | tbowman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-29-2007 01:52 PM |
setting up external drive | Mr Layz | Pro Tools M-Powered (Win) | 1 | 11-16-2006 05:25 AM |
setting up external drive | terryd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-09-2005 03:23 PM |
Error when setting hard drive to "record" | Sarzzo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-13-2004 07:42 AM |
Setting up an external drive using a "used" drive | basschair | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-15-2003 11:45 AM |
