Old 10-14-1999, 08:40 AM
kit2752 kit2752 is offline
Default pro tool authorize key and........
why I couldn't run authorise key when computer asking (it is the authorise key that I insert)?
my system is OS8.6
G3 450 and scsi accelerator is "adaptec domain 3940uw" and "quantum internal HD"(scsi2 connect to 3940)
should I change my internal HD to IDE one(connect to the mother board )?
3940 is it only for external HD use only?
thank you !!!
kit2752
Old 10-14-1999, 11:58 AM
Techsupt2 Techsupt2 is offline
Default Re: pro tool authorize key and........
kit2752
Depending on what floppy drive your using make sure you have the approperiate drivers installed and enabled for one of the two supported floppy drives and Pace copy protection.
The Imation SuperDisk requires these drivers:
-USBSuperDiskDriver v2.0a or latter www.superdisk.com
-USB Floppy Enabler v1.2 or latter www.paceap.com
The Newer Technology uDrive require these drivers
-uDrive Driver v1.0 www.newertech.com
-uDrive Shim v1.0 www.newertech.com
-USB Floppy Enabler v1.3 or latter www.paceap.com
Brad
Old 10-14-1999, 10:31 PM
Hi Brad,
Just received your message about not able to run the authorized key...
I will check on my computer to make sure whether the driver for imation floppy drive was installed.
Please tell me whether my system has any conflict when using Pro Tools?
my system is OS8.6
G3 450 and scsi accelerator is "adaptec domain 3940u2w" and "quantum internal
HD"(scsi2 connect to 3940) which is connected directly to 3940
Should I change my internal HD to IDE for system and application softwares only(directly connect to the mother board and not
connect to3940?) because someone told me this is the "only way" to use 3940. They told me that the HD that has system
software cannot go through 3940. Is this true? In fact, I doubt it very much.....
Thank you for your help!!!
Ellen
kit2752
HELP! - TL Space Native Authorize?!? It won't authorize! rotator Pro Tools 9 1 09-02-2011 04:50 AM
pro tool 9 can't authorize with iLok d2pc Pro Tools 9 5 06-26-2011 07:22 AM
Get Grabber tool (Object) as part of smart tool? buckaroo Pro Tools TDM Systems (Mac) 8 07-13-2010 04:21 AM
Pencil tool turns into mouse pointer tool when drawing arvid.lind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-11-2010 12:36 AM
Authorize problem when starting Pro Tool. Piano - 2008 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-24-2008 12:52 PM
