Old 07-22-2020, 01:04 AM
rogermf rogermf is offline
Default Re: Can't create 192kHz session on Pro Tools HD 10
So we tried today to connect just one 192IO to one of the TDM cards, without any word clock or any other type of sync.
It is the usual card it gets connected to, so it is the right type of card (CORE) and it usually works.
The 192 didn't seem however to lock or connect to the TDM card.
Maybe the SYNC HD is needed because the cards are in a Magma expansion chassis (PE6R4-I)?
Or maybe there's just some kind of weird thing going on with this particular 192.
Old 07-23-2020, 05:37 AM
priorytools priorytools is offline
Originally Posted by rogermf View Post
Thanks Dave! They are located close to the computer, connected using digilink cables shorter than 1m.
We'll be able to do some new tests tomorrow!
In your playback Engine, I seem to remember the number of voices you have selected effects the sample rates available. .
Try setting it to the smallest number of voices, then see if you can make a 192 kHz session.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 07-23-2020, 06:35 AM
No the sync HD is not needed. You need to troubleshoot stuff and work out what is going on. Swapping components/cables carefully and using Digitest.
Old 07-23-2020, 07:31 PM
We'll take a look at that, thanks!
Old 07-23-2020, 07:33 PM
Thanks Darryl, knowing the SYNC HD is not needed really helps.
We'll troubleshoot and update if we find the solution.
Thanks everyone for all the help!
Pro Tools 12 can’t create a new session PeteB Pro Tools 12 1 04-07-2019 10:03 AM
Pro Tools can't create a new session Donz Pro Tools 11 6 06-18-2014 05:43 PM
192khz session not even an option. Jakay macOS 18 09-18-2013 08:09 PM
Vacuum patch gets shorter decay time at 96kHz session than 192kHz session chrisdee Virtual Instruments 21 10-07-2011 10:02 AM
Convert 192kHz session to 96 rososound Pro Tools TDM Systems (Mac) 3 03-17-2007 12:55 AM
