Old 02-26-2019, 01:39 PM
MusicMadness MusicMadness is offline
Default Automatically create subpath
Is it possible to disable it? Every time I create a new stereo aux and route to this track PT automatically makes mono subpaths which I never use and it only makes my bus list much longer.
PT HD 2018.1, Mac Pro 2013, Digidesign Command 8, Focusrite Clarett 2Pre
Old 02-26-2019, 01:42 PM
its2loud its2loud is offline
Default Re: Automatically create subpath
Yes. Uncheck this box
Old 02-28-2019, 03:26 AM
yes, but to do this I need to go to I/O settings window first and create a bus there. I had this box unchecked anyway. What I want to do is to create a new aux in mixer view, give it a name, select some audio tracks and select output->track->(name od my newly created aux). This way PT automatically creates a bus called the same as the aux, sets it as outputs for my audio tracks and as input for the aux. It's just the bus created this way has subpaths regardless the unchecked box in I/O settings
Old 03-02-2021, 07:53 PM
MixerGuy MixerGuy is offline
I am curious about this as well...
and indeed - even if "Auto-Create Sub Paths" is UNCHECKED - when I create a new aux in the mixer window... it does create these messy mono sub paths i do not want.
any fix? or a future bug fix?
thx.
Copy clip - automatically create a new file? Richard901 Pro Tools 10 7 09-06-2016 09:30 PM
I didn't have "Automatically Create New Playlist in Loop Recording" checked... tooold macOS 3 02-09-2015 08:25 AM
Automatically create new playlists not working with midi eyjolfurg Pro Tools M-Powered (Win) 2 05-27-2009 03:16 PM
LCRS subpath on a 5.1 output Frank Kruse Post - Surround - Video 7 06-17-2008 08:27 AM
How do I create sequential track outputs automatically????? david kowalski Tips & Tricks 7 04-08-2002 11:07 AM
