Old 03-20-2012, 03:10 PM
Midimax Midimax is offline
Default 2 instrument tracks each controlled by different MIDI input/instrument
I would appreciate help with setting up my tracks in PT9 MP as I have very limited knowledge of MIDI setup and PT.
I would like to be able to control/record two instrument tracks using two external devices - 1 track controlled by 1 device:
M-Audio Axiom pro 61 MIDI controller - connected via USB (Hypercontrol)
Nord Electro 3 (monotimbral) - connected via MIDI OUT + MIDI IN of M-Audio FastTrack C400 - NE3 sends/receives MIDI data only on channel 1 by default
I am trying to make Track 1 play and record the virtual Vacuum instrument via Axiom and Track 2 play the audio and record midi data of my NE3, so I set up the tracks like this:
MIDI Input of Track 1 set to AxiomPro61HyperControl All Channels
MIDI Output of Track 1 set to the plugin Vacuum 1-1 (automatically after setting the insert/plugin to this track)
MIDI Input of Track 2 set to C400 Channel 1
MIDI Output of Track 2 set to none or to C400 Channel 1
Audio Input of Track 2 is set to C400 Analog 1-2 Input.
I end up with two undesired results depending on whether the MIDI Thru opiton is selected or deselected.
1. MIDI Thru selected:
if the last clicked/selected MIDI Output was Track 1 Vacuum 1-1 then it Axiom plays this intrument but no MIDI is recorded on this track, NE3 plays both the NE3 sound plus the Vacuum plugin sound and Track 2 records MIDI data.
if the last clicked/selected MIDI Output was Track 2 C400 Channel 1 then both Axiom and NE3 play only NE3 sound and only Track 2 records MIDI data.
2 MIDI Thru deselected:
Track 1 is mute - no midi input from Axiom gets to the Vacuum plugin.
Track 2 plays and records MIDI data when I play NE3.
I believe that there is a way to achieve what I was trying to do and I hope that my English is good enough for you to understand my description.
Thanks a lot for any help.
MIDI Input Selector Not Working on Instrument Tracks? kafka MIDI 0 08-02-2011 06:50 PM
RTAS instrument not receiving midi input parke02 Pro Tools M-Powered (Win) 9 12-08-2008 07:10 PM
Midi Input drops out on just Instrument tracks? Hp trigger Pro Tools TDM Systems (Mac) 0 09-14-2007 04:40 PM
No Instrument Insert on Instrument tracks Bazbo Virtual Instruments 4 03-01-2007 06:00 AM
No sound from "Aux Input" and "Instrument" tracks slowdude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-25-2005 03:46 AM
