Old 08-19-2009, 09:31 AM
KGB2011 KGB2011 is offline
Default Re: Which processor is better for Pro Tools M-powered
Here is a link with my sandra report http://www.zshare.net/download/643482829f4bcffe/
***** Start of Report *****
<<< Server Status >>>
Name: SiSoftware Sandra Lite [Evaluation] (x86)
Version: 2009.9.15.124
Copyright: Copyright © SiSoftware 1995-Present. All
Rights Reserved.
Registered Owner: PAUL
Registered Organisation: ACASA DEOCAMDATA
Licence Status: Evaluation copy, strictly for personal/
educational use only. For business/commercial
use, it can be trialled for 21 days.
Licence Extra: You are on day %i of your evaluation period.
Please see the SiSoftware site (http://
www.sisoftware.co.uk) for purchase details.
URL: http://www.sisoftware.net/sandra/
E-Mail: [email protected]
Host Name: acasa-5d02f4d9c
User: PAUL
System ID: {9414A68C-5029-4C75-8F8F-87D7C72E485F}
Result ID: {357502E8-61B9-4F3F-A255-5AF6F1C7C313}
Date: Wednesday, August 19, 2009 @ 6:57:46 PM
<<< Report Comments >>>
<<< Computer Overview >>>
< Computer >
Model: System manufacturer System Product Name
Workgroup: WORKGROUP
User: PAUL
< Processor >
Model: Intel(R) Core(TM)2 Quad CPU Q8300 @
2.50GHz
Speed: 2.5GHz
Cores per Processor: 4 Unit(s)
Threads per Core: 1 Unit(s)
Type: Quad-Core
Integrated Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64
byte line size
L2 On-board Cache: 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte
line size, 2 threads sharing
< Computer >
Mainboard: Asus P5Q SE2
BIOS: American Megatrends Inc. 0406 10/07/2008
Bus(es): ISA X-Bus PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support: No
Multi-Processor Advanced PIC (:Yes
Total Memory: 3GB DIMM DDR2
< Chipset >
Model: ASUS P45/P43/G45/G43 DRAM Controller
Front Side Bus Speed: 4x 334MHz (1.34GHz)
Memory Bus Speed: 2x 334MHz (668MHz)
< Memory Module(s) >
Memory Module: Kingmax KLCD48F-A8KB5 1GB DIMM DDR2 PC2-5300U
DDR2-666 (5-5-5-15 3-20-5-3)
Memory Module: Kingmax KLCE88F-B8KU5 2GB DIMM DDR2 PC2-5300U
< Video System >
Video Adapter: NVIDIA GeForce 8600 GT (32 SP 1.1GHz, 512MB
DDR2 2x400MHz, PCIe 1.00 x16)
< Storage Devices >
WDC WD1600AAJS-00PSA0 (160GB, :149GB (C:) (D:)
ST3640323AS (640.1GB, SATA300,:596GB (G:)
HL-DT-ST DVDRAM GSA-H10N (ATA3:N/A (E:)
IT6253Q BAR213T (SCSI, SCSI-2,:535MB (F:)
IT6253Q BAR213T (SCSI, SCSI-2,:N/A (H:)
< Logical Storage Devices >
Hard Disk (C:): 49GB (NTFS) @ WDC WD1600AAJS-00PSA0 (160GB,
SATA300, 3.5", 7200rpm, NCQ, 8MB Cache)
Hard Disk (D:): 100GB (NTFS) @ WDC WD1600AAJS-00PSA0 (160GB,
Local Disk (G:): 596GB (NTFS) @ ST3640323AS (640.1GB, SATA300,
3.5", 7200rpm, NCQ)
Optical Drive (E:): N/A @ HL-DT-ST DVDRAM GSA-H10N (ATA33, DVD+-
RW, CD-RW, 2MB Cache)
Acoustic Guitar (F:): 535MB (CDFS) @ IT6253Q BAR213T (SCSI, SCSI-2,
DVD+-R-DL, CD-R, 512kB Cache)
Optical Drive (H:): N/A @ IT6253Q BAR213T (SCSI, SCSI-2, DVD+-R-
3.5" 1.44MB (A:): N/A
< Peripherals >
LPC Hub Controller 1: ASUS LPC Interface Controller
LPC Legacy Controller 1: T0 A5-13h
Audio Device: ASUS HD Audio Controller
Audio Device: VIA M Audio Audiophile
Serial Port(s): 1
Disk Controller: ASUS 4 port SATA IDE Controller
Disk Controller: ASUS 2 port SATA IDE Controller
Disk Controller: ASUS 6101 SATA2 Controller
USB Controller 1: ASUS USB UHCI Controller #4
USB Controller 2: ASUS USB UHCI Controller #5
USB Controller 3: ASUS USB UHCI Controller #6
USB Controller 4: ASUS USB EHCI Controller #2
USB Controller 5: ASUS USB UHCI Controller #1
USB Controller 6: ASUS USB UHCI Controller #2
USB Controller 7: ASUS USB UHCI Controller #3
USB Controller 8: ASUS USB EHCI Controller #1
SMBus/i2c Controller 1: Intel 801xx/63xx SMBus
< Printers and Faxes >
Printer: Microsoft Office Document Image Writer Driver
(300x300, Colour)
< Network Services >
Network Adapter: Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit
Ethernet NIC - Packet Scheduler Miniport
(Ethernet, 100Mbps)
< Power Management >
Mains (AC) Line Status: On-Line
< Operating System >
Windows System: Microsoft Windows XP Professional 5.01.2600
(Service Pack 2)
Platform Compliance: x86
<<< Processor Arithmetic >>>
< Benchmark Results >
Aggregate Arithmetic Performan:39.74GOPS
Dhrystone ALU: 42.86GIPS
Whetstone iSSE3: 36.61GFLOPS
Results Interpretation: Higher index values are better.
< Performance vs. Speed >
Aggregate Arithmetic Performan:15.84MOPS/MHz
Dhrystone ALU: 17.09MIPS/MHz
Whetstone iSSE3: 14.60MFLOPS/MHz
< Performance vs. Power >
Processor(s) Power: 125.57W
Aggregate Arithmetic Performan:316.45MOPS/W
Dhrystone ALU: 341.35MIPS/W
Whetstone iSSE3: 291.57MFLOPS/W
< Performance Test Status >
Result ID: Intel(R) Core(TM)2 Quad CPU Q8300 @
2.50GHz (4C, 2.5GHz, 2x 2MB L2, 1.34GHz FSB)
NUMA Support: No
SMP (Multi-Processor) Benchmar:Yes
Total Test Threads: 4
Multi-Core Test: Yes
SMT (Multi-Threaded) Benchmark:No
Processor Affinity: P0C0T0 P0C1T0 P0C2T0 P0C3T0
System Timer: 2.5GHz
Number of Runs: 64000 / 640
< Processor >
2.50GHz
Speed: 2.5GHz
Peak Processing Performance (P:40.13GFLOPS
Adjusted Peak Performance (APP:12WG
Type: Quad-Core
byte line size
< Features >
SSE Technology: Yes
SSE2 Technology: Yes
SSE3 Technology: Yes
Supplemental SSE3 Technology: Yes
SSE4.1 Technology: Yes
SSE4.2 Technology: No
AVX - Advanced Vector eXtensio:No
FMA - Fused Multiply/Add eXten:No
SSE4A Technology: No
FMA4 - 4 Operands Fused Multip:No
HTT - Hyper-Threading Technolo:No
< Performance Tips >
Notice 5008: To change benchmarks, click Options.
Notice 5004: Synthetic benchmark. May not tally with 'real-
life' performance.
Notice 5006: Only compare the results with ones obtained
using the same version!
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
<<< Processor Multi-Media >>>
Aggregate Multi-Media Performa:72.6MPixel/s
Multi-Media Int x8 iSSE4.1: 93MPixel/s
Multi-Media Float x4 iSSE2: 52.25MPixel/s
Multi-Media Double x2 iSSE2: 26.27MPixel/s
Aggregate Multi-Media Performa:28.95kPixels/s/MHz
Multi-Media Int x8 iSSE4.1: 37.07kPixels/s/MHz
Multi-Media Float x4 iSSE2: 20.83kPixels/s/MHz
Multi-Media Double x2 iSSE2: 10.47kPixels/s/MHz
Aggregate Multi-Media Performa:578.22kPixels/s/W
Multi-Media Int x8 iSSE4.1: 740.33kPixels/s/W
Multi-Media Float x4 iSSE2: 416.12kPixels/s/W
Multi-Media Double x2 iSSE2: 209.21kPixels/s/W
NUMA Support: No
Rendered Image Size: 1920x1080
< Processor >
2.50GHz
Speed: 2.5GHz
Type: Quad-Core
byte line size
< Features >
SSE Technology: Yes
life' performance.
tip.
<<< Multi-Core Efficiency >>>
Inter-Core Bandwidth: 9.8GB/s
Inter-Core Latency: 53ns
Results Interpretation: Lower index values are better.
Inter-Core Bandwidth: 4.01MB/s/MHz
Inter-Core Latency: 0.02ns/MHz
Inter-Core Bandwidth: 80.00MB/s/W
Inter-Core Latency: 0.42ns/W
< Capacity vs Power >
Total Cache Size: 166.03kB/W
< Detailed Benchmark Results >
Processor Affinity: CPU0-CPU1 CPU2-CPU3
2x8kB Blocks Bandwidth: 8GB/s
4x8kB Blocks Bandwidth: 8.78GB/s
2x32kB Blocks Bandwidth: 10.59GB/s
4x32kB Blocks Bandwidth: 21.44GB/s
16x8kB Blocks Bandwidth: 20.36GB/s
2x128kB Blocks Bandwidth: 22.1GB/s
4x128kB Blocks Bandwidth: 22.17GB/s
16x32kB Blocks Bandwidth: 21.71GB/s
64x8kB Blocks Bandwidth: 20.35GB/s
16x128kB Blocks Bandwidth: 2.31GB/s
64x32kB Blocks Bandwidth: 3GB/s
64x128kB Blocks Bandwidth: 1.6GB/s
Buffering Used: No
NUMA Support: No
Page Size: 4kB
Use Large Memory Pages: No
< Processor >
2.50GHz
Speed: 2.5GHz
Type: Quad-Core
byte line size
life' performance.
Tip 11: Use the 'Switch Chart Type' button to switch
between Detailed and Combined charts.
tip.
Old 08-19-2009, 09:44 AM
<<< Power Management Efficiency >>>
<< ALU Power Performance >>
<< 50i/25Hz (25fps, e.g. interlaced PAL video) >>
ALU Power Performance: 12.8GIPS
Power Efficiency: 0.00
ALU Power Performance: 5.11MIPS/MHz
ALU Power Performance: 101.98MIPS/W
< APM System Status >
Processor Dynamic Throttle Pol:None
Optimised for Performance: Yes
NUMA Support: No
SMP (Multi-Processor) Benchmar:No
< Breakdown at 500 MIPS Workload >
Average Clock Ratio: 100% (2.5GHz)
Average Voltage Ratio: 100% (1.138V)
< Breakdown at 1000 MIPS Workload >
< Breakdown at 1500 MIPS Workload >
< Breakdown at 2000 MIPS Workload >
< Breakdown at 2500 MIPS Workload >
< Breakdown at 3000 MIPS Workload >
< Breakdown at 3500 MIPS Workload >
< Breakdown at 4000 MIPS Workload >
< Breakdown at 4500 MIPS Workload >
< Breakdown at 5000 MIPS Workload >
< Breakdown at 6000 MIPS Workload >
< Breakdown at 7000 MIPS Workload >
< Breakdown at 8000 MIPS Workload >
< Breakdown at 9000 MIPS Workload >
< Breakdown at 10000 MIPS Workload >
< Breakdown at 11000 MIPS Workload >
< Breakdown at 12000 MIPS Workload >
< Breakdown at 13000 MIPS Workload >
< Breakdown at 14000 MIPS Workload >
< Breakdown at 15000 MIPS Workload >
< Breakdown at 16500 MIPS Workload >
< Breakdown at 18000 MIPS Workload >
< Breakdown at 19500 MIPS Workload >
< Breakdown at 21000 MIPS Workload >
< Breakdown at 22500 MIPS Workload >
< Breakdown at 24000 MIPS Workload >
< Breakdown at 25500 MIPS Workload >
< Breakdown at 27000 MIPS Workload >
< Breakdown at 28500 MIPS Workload >
< Breakdown at 30000 MIPS Workload >
< Breakdown at 32000 MIPS Workload >
< Processor >
2.50GHz
Speed: 2.5GHz
Type: Quad-Core
byte line size
life' performance.
Tip 1108: Processor power policy not optimal. For best
power management efficiency, choose the
adaptive mode.
tip.
<< 60i/30Hz (29.97fps, e.g. interlaced NTSC video) >>
NUMA Support: No
< Processor >
2.50GHz
Speed: 2.5GHz
Type: Quad-Core
byte line size
life' performance.
adaptive mode.
tip.
<< 50p (50fps, e.g. progressive PAL video) >>
NUMA Support: No
Old 08-19-2009, 09:45 AM
< Processor >
2.50GHz
Speed: 2.5GHz
Type: Quad-Core
byte line size
life' performance.
adaptive mode.
tip.
<< 60p (59.94fps, e.g. progressive NTSC video) >>
Old 08-19-2009, 10:15 AM
I did a screen capture with the message and with the four cores usage being to 100 %.
http://www.zshare.net/image/64350282f4942044/
Old 08-19-2009, 10:19 AM
spkguitar's Avatar
Mixing/matching RAM like this is not doing you any good, and could be causing problems. You want a matched set.
< Storage Devices >
Are those "virtual drives"? They look like it. Pro Tools does not support the use of virtual drives. Make sure they are disabled when using Pro Tools.
  #16
Old 08-19-2009, 10:29 AM
I disabled the virtual drives.
You mean that Ram aren't placed in the corect slots ? or that they are not compatible with each other ?
What to do ?
  #17
Old 08-19-2009, 10:31 AM
spkguitar's Avatar
You've got a lot of other stuff running while you are using Pro Tools... I see Avast, and what looks like a "virtual dongle" (I'm guessing that's to authorize reFX Nexus which requires a REAL dongle for authorization)? Also some other things... all could be interfering with Pro Tools.
Check my signature...
  #18
Old 08-19-2009, 10:32 AM
spkguitar's Avatar
No, they should be matched... 2GB and 2GB. same/same. Not one 1GB stick and one 2GB stick.
  #19
Old 08-19-2009, 11:01 AM
Even if i disable and close all those things i got the same problem. And even so with a 2,5 ghz quad core they should all work.
One thing that i forgot to mention is that i didn't reinstalled windows when i changed motherboard and processor.
  #20
Old 08-19-2009, 11:16 AM
spkguitar's Avatar
Yeah, I know; I'm the one recommending that you do that in your other thread.
mac osx, m powered fast track, pro tools m powered singdance6 Pro Tools M-Powered (Mac) 2 12-22-2010 09:24 AM
Please Advise are Pro Tools M-Powered Essential the same as LE M-Powered? jeremiah0812 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-19-2010 10:10 AM
optimizing processor power for PT M-Powered nonsqtr Pro Tools M-Powered (Win) 1 10-03-2010 03:03 PM
Help building a quiet quad processor PC for M-powered. headswimmer Pro Tools M-Powered (Win) 0 05-20-2008 01:29 AM
M-Powered on Cube with faster processor? John Link Pro Tools M-Powered (Mac) 5 03-04-2006 06:30 PM
