Old 05-12-2006, 02:57 PM
rockridge98 rockridge98 is offline
Default How to double-time a MIDI region?
Question for you PT MIDI experts:
Lets say I have a 2 bar MIDI region in 4/4 containing 8 notes (1 quarter note per beat).
Is there some region editing command in PT to change it into a single bar region
playing twice as fast, ie change it into a single bar with 8 8th notes.
For those of you who know Sibelius
this would be like using the "Double Note Values" or Halve Note Values plugins.
I've RTFM'd but can't find it.
thanks...
Also, if there was a utility program that would do this on MIDI files, that would be almost as good.
Old 05-12-2006, 03:25 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: How to double-time a MIDI region?
Time stretch midi in PT7 might give you what you want! operates same as audio time stretch
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-12-2006, 03:52 PM
jeremyroberts jeremyroberts is offline
use the TCE tool (in grid mode, set trimmer to TCE) - drag from 2 bars to 1
PS -- the ****** manual is a PDF file in your help menu.
You can search it. hence, the acronym STFM; Search The...
It took me 8 seconds to find page 425 answers your question.
--Jeremy
Old 05-12-2006, 04:34 PM
Thanks to all! It wasn't in the hardcopy index (I looked at every entry that said MIDI),
but you guys are right that a STFM would have found it, so I will make a point of
doing that next time.
double time or halfe time some midi in PT???? metaltim MIDI 10 05-21-2013 03:10 PM
Double clicking a region brings up the wrong midi editor cudithekid Pro Tools M-Powered (Win) 2 01-31-2012 05:17 PM
Region stuck at double speed playback ?! antonis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-30-2009 01:20 PM
Happened again - Double-click MIDI region CRASH (Reboot) GordonFreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 04-04-2009 01:10 PM
How to Double Time (or Time Stretch) Midi? noharmlessrock MIDI 4 04-02-2008 07:32 PM
