Mirrored Midi Editing Ghost?
So, I'm not sure what's happening here...
I repeated a drum region several times, turned off mirrored midi, etc. And yet, when I try to modify the drum loop, it still alters every subsequent loop in the same manner (same can be said for synths, etc). I know I'm missing something simple here...and after quite an internet search, I'm still stuck. Any ideas? |
Re: Mirrored Midi Editing Ghost?
I think you have to turn off mirrored midi editing before you repeat the region (clip)
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0 http://www.pelhamundhaas.de/index2.html http://www.pelhamundhaas.de/vita.html www.3-p.de www.imglashaus.de |
If you're using the loop trim tool, it just creates aliases of your original (it will show little arrows on the bottom of the loops) that follow the original regardless of your mirrored setting. . To create discrete clips, use cmd+D or option-drag the region. Then they behave according to the Mirrored MIDI Editing setting.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Just checked, I was wrong, mesaone is right.
Would you mind taking a screenshot of your edit window?
Nope, you're not dumb, you have everything in order. Mirrored Midi Editing is off, your MIDI clips are discrete.
Try renaming the subsequent MIDI clips, maybe that will "break" the association. After that, I'd say the best thing to try at this point is to trash preferences. If that doesn't do the trick, try to find out if this is happening to all sessions or just certain sessions.
I'm losing my mind. There's gotta be some simple little dialogue box I checked or need to check... Anybody? |
mirrored audio editing?!? | modulate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-26-2009 04:16 AM |
Mirrored MIDI Editing | filosofem | MIDI | 0 | 09-12-2008 04:51 PM |
Mirrored MIDI Editing, what am I missing? | clampire | MIDI | 3 | 03-21-2008 07:05 PM |
Mirrored MIDI Editing is ON by default in 7.3 | jeremyroberts | Pro Tools TDM Systems (Mac) | 3 | 11-30-2007 11:22 PM |
"Ghost" Notes in Piano Roll editing | Andrew Cleaton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-26-2003 04:41 AM |
