#81
Re: Codec error on video import
It's a Quicktime Movie File.
I just did the following: Opened activity monitor and found the "Avid Video Engine" Process. Selected force quit. Pro tools gave an error and I clicked ok. video engine relaunched and video imported again, but is still black... |
#82
Sounds like the problem has to do with having an older AMA plug-in mixed with newer PT11 or MC7 AMA plug-ins. You should check the AMA folder (applications Support/Avid/AVX2 plug-ins).
Anything in this folder older than Aug 2013? You could also move that folder to the desktop and do an uninstall - reinstall. You could also try just moving the AVX plug-ins out of that folder (to a safe folder on the desktop). Launch PT and see if video import works. Add the plug-ins back 1 at a time until you find the culprit. |
#83
Problems here to:
"missing codec" No Media Composer Installed No AVA plugins whatsover Installed that codec pack floating around using vanilla h264 quicktimes 16GB Ram OSX 10.7.5 What's the deal? Was really hoping 11 could fix the pesky -2015 errors my bounce to QTs in 10 were getting. Fix your sh...'tuff Avid! |
#84
+1
Same here. Fresh install on Mavericks. Pro Tools 11.1.2. No pug ins in AVX2 folder. No MC6/7 installed. Installed Codec Package from Pro Tools Installer. Repaired permissions. Double checked Read/Write. Restarted several times. Nothing. Anything else I can do? |
#85
This CODEC error is happening for me too. Until this day there haven't been any importing problems. Suddenly I can't import ProRes/PhotoJPEG videos like yesterday. 11 has been problem free for me.. not anymore. Prefs trashed/permissions repaired.
I can still import DV/mp4. Last edited by P_J; 03-21-2014 at 03:58 AM. |
#86
Ok. I found a solution for my problem and this time the reason was Apple’s Compressor.
I’ve been using Compressor with two different computers. Same version, same presets. I noticed that second Compressor's Preferences > Advanced > Enable Additional Compressor instances is checked. I unchecked that and now I’m able to import ProRes/PhotoJPEG again. I’m always compressing videos to ProRes or PhotoJPEG before I start to work. Other day I reseted one Compressor queue and during this operation I checked EACI by mistake (I think). Although PT10 opens all those files ok. |
#87
Video import problems in PT11 - PT10 works fine with Video
having same issues as many others , same error messages .. "This session contains media that is not supported possibly due to missing CODEC." and "Unable to link to files xxxx due to either missing codec or file may be unsupported" -------- -------- -------- MY SYSTEM MacBook Pro 13" - 2009 / 2010 2.26GHz Intel Core 2 Duo 8 GB RAM OSX 10.8.5 QuickTime Version - 10.2 PT 10 - 10.3.7.296 / August 7, 2013 PT 11 - 11.1.2.214 / January 16, 2014 ------- ------- -------- nothing installed in the AVX2_plug-ins folder (path > library/application support/Avid/AVX2_plug-ins ) I did download most recent AvidCodecsLE pkg and installed using mpeg Streamslip to transfer - tried > Avid DNxHD , h.264 to .mov file all encoded .mov do open and play in QuickTime 10 player. ----- ----- ---- REGARDING QUICKTIME - I found this in the tech support pages QuickTime Player is not currently compatible with Avid Audio Interfaces on Mac OS X 10.8 (PTSW-163965) QuickTime Player is not currently compatible with Avid Audio Interfaces on Mac OS X 10.8 (PTSW-163965) QuickTime Player does not currently support Avid audio devices as output devices with Mac OS X 10.8. Audio will not pass through and playback will not start. Please use an alternate audio interface for QuickTime Player, or use another software solution for playing back QuickTime files with Avid audio devices as a workaround for this issue. ------- ------ ------- I see that many users are using QuickTime 7 and QuickTime 7 Pro ? I did find QuickTime 7 Pro is still available from the Apple website - store .. .. .. but , unsure about having different version of Quictime in 107 , 10.8 or Mavericks .. since Apple is pushing QuickTimeX which I read several negative reviews due to not being able to enter custom settings. ------------------------------- I have been using ProTools since the beginning days … I am an Audio Engineer - Class A Studio Background - Analog sync ProTools / Digital I am not a Post or Editor use iMovie ( ver 6 and 8) . but considering Final Cut X .. also looking into iMovie 9 ad 11 ??? My Goal on this Audio / Video Project is to get the best quality Final Product to send out for Copies for client. I gladly could use help from any of U experienced Post Editors as to settings to use .. tips , etc Please feel free to contact me by email - I am in the middle of a long Audio / Video project and would prefer to use PT11 if possible .. .. *** note - I have spent several days .. maybe a week ( or more) searching the DUC and net for solutions … these type situations certainly make work WORK and also when just writing /creating .. makes music not so fun ..
rokalias |
#88
I'm also having same issues as below + the video thumbnail problem. Videos which imports just fine on one time randomly stops working after reloading sessions another time. Reimporting or any other suggested thing doesn't help. I'm running 11.1.2 HD with an Avid qualified iMac. PT11 is almost completely unusable for me because of this.
#89
I have PT10.6.8 on an approved DELL model and have a problem with MOV files as well. Some of the MOV files give me a white box when put on the time line. Just sound and no picture. Is there a codec missing from PT???? And with a straight answer, what exactly should the details of the MOV codec be. I want to see it all right down to the bit rate. Max file size? Depth? Just a simple list will do.
#90
The codecs issue was fixed in 11.1.3, I believe.. Along with a bunch of other video-related fixes.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Error message when trying to import a video to a session | cedlil | Pro Tools 11 | 0 | 03-03-2014 09:11 AM |
Solving a Codec Error when importing video | Dizz | Tips & Tricks | 0 | 10-04-2013 05:14 PM |
Import Video error -2015 | matt connolly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-28-2009 03:57 PM |
IMPORT VIDEO ERROR Audio FILE | alx002 | Pro Tools TDM Systems (Mac) | 1 | 10-01-2008 12:31 PM |
Video import Error | SteveH44 | Post - Surround - Video | 0 | 09-10-2008 12:00 PM |
