Old 05-02-2004, 10:40 AM
Siberian Siberian is offline
Default Major crash... need some help...
System locked up, can't reboot, keep getting error message at boot-up that says
"winlogon.exe- Bad Image
The application or DLL C:\windows\system32\shlwapi.dll is not a valid windows image. Please check this against your installation diskette"
I have tried booting into safe mode, and rebooting with the XP disk and this error keeps coming up. I can't get into safe mode.
Any ideas on how to get around this?
Old 05-02-2004, 10:50 AM
AfricanCaneKing AfricanCaneKing is offline
Default Re: Major crash... need some help...
it might be time to re install windows, when things get that bad it usually means you have corrupted critical system files. if you have windows 98 you might be able to find "shlwapi.dll" on the install cd and expand it into your windows directory, but there is no guarantee that will work. if you have win xp, try and use system restore to restore the system to a date before the problem started showing up.
once again the best thing to d is wipe clean and re install everything from scratch
2.0GHz Intel Core 2 Duo + 2GB RAM
el-cheapo compusa generic firewire 80GB
OSx 10.4.10, PTLE 7 (latest update)
Old 05-02-2004, 11:05 AM
cyrick cyrick is offline
Did this happen to occur shortly after a Service pack or web based update? There are a few options before you start over.
Can you boot the CD room and get to the setup screen?
Old 05-02-2004, 11:20 AM
It's Windows XP. I have inserted the XP disk and booted from the CD rom. I got to the repair utility, but I'm not quite sure what to do from there. **now checking microsoft website support for help**
Old 05-02-2004, 01:05 PM
KingFish KingFish is offline
Do not go into the "repair" or "recovery console" from booting off the XP CD -
Follow instructions as though you were going to do a fresh install - then AFTER you've hit F8 agreeing with their licence, you select the partition to install XP on, (where your current installation already is) it will detect a previous version of XP, and give you the option to just repair that installation, Choose that option.
You won't loose any of your files, or personal settings, it's way easier to repair windows this way then by hitting "R" after first booting off the XP CD.
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 05-02-2004, 06:44 PM
Okay, I did it that way... Except it re-installed Windows, even though I hit "R" for repair. Oh well, no biggie. It's fixed now. I just need to go back in and re-do all of my personal settings, and disable all the useless crap in XP that I wasn't using.
Old 05-02-2004, 06:50 PM
Allen Hallada Allen Hallada is offline
Hea hea,
good answer.
Allen
Major Crash with PT 7.3 cs5 crash report included RuffJazzRecords Pro Tools M-Powered (Win) 0 02-09-2008 12:43 PM
Need Help with major crash dialogue box scott waz Post - Surround - Video 3 02-04-2007 03:10 AM
PT 7.3.1 major crash!!! Ash06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-22-2007 04:20 PM
LE 6.7 Major Crash rsvpmus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-27-2004 07:16 AM
major crash..NEED HELP firedog57 Pro Tools TDM Systems (Mac) 3 04-27-2004 11:31 AM
