  #31
Old 09-25-2016, 04:54 PM
EddieJones's Avatar
Default Re: Assign Module Hardware not working
I messaged you...can you first uninstall the Master Module software and reinstall so we are starting fresh.
  #32
Old 09-25-2016, 04:56 PM
ampnerd ampnerd is offline
Yes, how do I do that? Sorry...
  #33
Old 10-11-2016, 05:36 AM
creativecontrol's Avatar
Settings > About > Logout. Touch Administrator. The Password = password. When you get to the desktop you can simply swipe from the right edge of the screen to the left to bring up the toolbar. Choose Settings > Control Panel > Programs and Features. Find S6 Master Module in the list and then touch Uninstall. Done.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #34
Old 09-09-2020, 03:19 PM
skilletaudio skilletaudio is offline
Yeah I am in the same boat with three modules lit purple on a bran new out of the box system. The shift purple is lit on the fader module and the bottom left config button is lit purple on two knob modules.
I have installed a bran new current version on the MTM and these are not working even after temporarly going into "Unclaimed Mode"
http://akmedia.digidesign.com/suppor...stem_88549.pdf
Temporarily Unclaiming a Module
If you forget to remove a module from the surface arrangement before physically moving it to another system, you can temporarily unclaim it after the new systems boots by holding the top two right-most switches on that module. However, it will reset back to its previous owner after a power cycle if not properly claimed by another system by adding it to that system’s arrangement.
Unclaiming Display Modules
To unclaim a Display Module:
1 Create a file named “unclaim.txt” and copy it to a FAT-formated USB flash drive.
2 Plug the USB drive into the Display Module you want to unclaim. After a few seconds, the Display Module screen displays a “Not Connected” message indicating that the process is complete.
3 Be sure to add the Display Module back to your configuration. While doing so in the Settings > Surface, Config screen, the mod- ule and/or its vacant slot might display red as if they are unavailable. This can be ignored, however, and you can drag the module back into the surface configuration to reclaim it.
  #35
Old 09-10-2020, 06:49 AM
It's also a good idea to go into diagnostic mode and see if the particular module(s) are getting valid IP addresses:
Joystick Module
Select + Swap (upper left)
Fader Module
Select + Swap (Channel 1)
Process Module
Clear + Func (Channel 1)
Knob Module
Select (Channel 1) + Select (Channel 2)
Automation Module
Select + Swap (Attention Track)
Master Module
Sel + In (next to Top Left Knob)
Master Post Module
Attention Switch + Link
Display Module
Control + Alt + Shift + V (Windows Keyboard)
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Can not assign module hardware amolin Avid S4/S6 2 05-06-2016 11:35 AM
D-command main module not working Boe Larsen Pro Tools HDX & HD Native Systems (Mac) 6 03-02-2015 09:38 AM
Icon D-Control fader module not working ramonpujol ICON & C|24 2 05-17-2014 02:24 PM
Main Module not working-Help icenet ICON & C|24 2 09-21-2013 01:01 PM
hardware piano module?? stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-30-2007 07:42 AM
