Old 05-23-2007, 11:43 AM
Palance Chase Palance Chase is offline
Default keystation 49e???
Hey guys, I got this problem I cant get my keystation 49e to work with protools, it works just fine in windows and with the mbox....but not in protools?? I have PT 7.3.1cs2
any suggestions?
thanks!
Old 05-23-2007, 11:49 AM
Jim Casey Jim Casey is offline
Default Re: keystation 49e???
any suggestions?
thanks!
Did you configure for it in peripherals?
Casey
You can hear what I'm doing at:
http://www.reverbnation.com/jimcasey
Old 05-23-2007, 02:56 PM
no, but I dont really get it how to do it?
Old 05-23-2007, 03:08 PM
Well, first it helps to go to the M-Audio website and download the new driver because it really is easier to configure.
I am not in Pro Tools right now because I am at work. But you configure it in peripherals in midi studio I think - you need to tell Pro Tools you have one and set it up. It's not hard, if you find the right menu choice you can figure it out. If you can wait until tonight I will post it when I can look at it.
Go get the new driver and install it.
Cheers.
Casey
Old 05-23-2007, 03:22 PM
yes I installed the new driver, and looking in the peripherals...but dunno...
just doesnt seem to work for me..
Old 05-23-2007, 04:21 PM
spkguitar's Avatar
If the device is installed properly in windows, the only thing you should have to do is select it in your MIDI or Instrument track's MIDI input dropdown.
That's seriously all there is to it.
There's no need to set it up under MIDI Studio Setup as it is just a controller and the only benefit that gives you is allowing you to rename the device.
The only reason to set it up inder "peripherals" is if you were trying to use it as a control surface to control the transport in Pro Tools. Since the keystation 49e has no transport controls, that point is moot.
Old 05-23-2007, 04:53 PM
Yeah, what he said.
Casey
Old 05-23-2007, 08:26 PM
I'm sure spkrgtr has it nailed he usually does.
I looked in my setup and I did set it up in Midi Studio under the setup menu. Setup-midi-midi studio. The reason I set anything up there in the first place was because I was troubleshooting - the Akai MPD 16 I think.
Anyway, mine is is configured "Keystation 49 in - Keystation 49 Out [emulated]" which you choose from the drop down menus under input port and output port. Send and receive channels both #1. Write the name of the unit in the space and don't bother with the manufacturer or model.
Casey
Old 08-16-2016, 12:15 AM
[email protected] danruiz79@gmail.com is offline
So to be clear the key station 49 does have transport controls, so its not a moot point. ugh...
Old 08-16-2016, 07:56 AM
Southsidemusic's Avatar
This thread is 9 years old and the same for the KeyStation so look for something on this side of 2015 andyou will find. Any great midi keyboards with controllers that you can use for basically anything.
Google is great for this task
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Keystation Pro 88 davidlustrup Pro Tools 9 12 11-22-2010 05:16 AM
keystation pro 88 benniesims 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-25-2006 12:14 PM
keystation pro 88 ssl4000 Pro Tools TDM Systems (Mac) 1 04-21-2005 09:43 AM
Keystation 49 Kipsey MIDI 0 03-19-2004 11:53 PM
Keystation 61 & OMS set up PJ Spain 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-13-2002 11:27 AM
