Go Back   Avid Pro Audio Community > Announcements > Technical Alerts
Old 11-30-2007, 07:59 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 7.4cs1 Updates for all 7.4 Systems
Available for download from the Pro Tools CS Updates page:
www.digidesign.com/support/csupdates
Pro Tools 7.4cs1 includes fixes for all Digidesign control surfaces on all platforms (HD, LE, M-Powered):
Fixed: Pro Tools quits unexpectedly when moving a plug-in window while closing it from a control surface (Item #99442)
- If a plug-in window was closed from a control surface while the plug-in window was being dragged across the screen, Pro Tools would quit unexpectedly.
Pro Tools LE and M-Powered owners that are not using a control surface with Pro Tools can skip this update.
Pro Tools HD 7.4cs1 also includes the following:
Fixed: When Transport = Machine and a linear deck is connected, Back and Play does not work (Item #99342)
- Under certain conditions the Back and Play command would not respond when transport was set to Transport = Machine.
Pro Tools HD owners that are not using a control surface with Pro Tools or MachineControl with a linear deck can skip this update.
Previous installation of Pro Tools 7.4 required to use these updates:New D-Control Features
Pro Tools HD 7.4cs1 also includes controller personality file and firmware updates for D-Control worksurfaces. These personality and firmware updates include the following new or updated features:
  • Changes to the "Auto Write To" Switches
  • Changes to the Soft Keys Section
  • Dual Transport Mode
  • LED Test Mode Color Changes (D-Control ES Only)
  • D-Control Multi-Mode (Mac only)*
*Pro Tools HD 7.4cs1 for Mac OS X adds the ability to enter D-Control Multi-mode, which lets you use a single D-Control console to access up to four Pro Tools|HD systems on a network. Multi-mode lets you quickly switch worksurface control from one Pro Tools system to another by pressing a single switch on the D-Control console. Please note that older consoles may require upgraded components to support Multi-mode. See the D-Control Addendum v7.4-7.4cs1 for more information.
For more about the new D-Control features, see the D-Control Addendum v7.4-7.4cs1 document avaliable from the Pro Tools HD 7.4cs1 pages.
Administrator
HTML code is On
Pro Tools 7.4cs4 Updates for all 7.4 Systems Avid Technical Alerts 0 04-24-2008 12:41 AM
Pro Tools 7.3.1cs5 Updates for All 7.3.x Systems Avid Technical Alerts 0 10-02-2007 10:02 PM
Pro Tools 7.3.1cs4 Updates for All 7.3.x Systems reelzman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-28-2007 06:32 PM
Pro Tools 7.3.1cs4 Updates for All 7.3.x Systems Avid Technical Alerts 0 07-26-2007 09:56 AM
Pro Tools 7.3.1cs1 Updates for All 7.3.x Systems Avid Pro Tools M-Powered (Win) 0 02-12-2007 11:11 PM
