superior Drummer Causing Pro Tools To Crash
[B]I recently installed Toontrack's Superior Drummer 2.0 and within a few minutes I get a PT EXE error and my computer crashes.
It happens every time I try to run the program. Does anyone else have this problem? Thanks.[/B] |
Re: superior Drummer Causing Pro Tools To Crash
yup. mine crashes when im over 1.3gb w/ the sample. will AVID do anything about it? NOPE! why? cause they dont care
Avid doesn't own toontrack, so why or how would they do something. I run it all the time.
The only time it crashes for me is if I don't set at least 1 output in the mixer to 1/2. I started a thread about that here. Make sure in the mixer (in SD) that at least one of the outputs are set for 1/2 out. If not it will crash PT. It is a bug in Superior Drummer. |
Don't get me wrong, I love Superior Drummer but it is definitely a memory hog. On older versions of PT (and especially if you are using XP), there are things you have to do to make it work. |
Its hard to help when we have no info on your system.
Help us help you - what you need to know before posting! And update SD2 to the latest update version(I think its 2.21). Anytime a plugin causes problems, checking for an update is the first thing to do.
It's an odd bug, but that's what makes it a bug.. As long as I mind this, it works perfectly for me... a great program too btw.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Yep. I like the program a lot, and set up a 1/2 bus and mute it then that covers the bug.
I downloaded the updates,set the bus to 1/2 bus etc,but I am still crashing .
Im at wits end with this thing. First the Runtime error comes up followed by PT Exe error and then it crashes. Please advise |
which update did you install? Just curious to see if I can have any insight into your problem
Hows about you help us out and post a sandra report and a little bit more info on what you are doing in the session that keeps tanking your rig..
Superior drummer 64 bit in pro tools 9 | Raoul23 | The Drum Room | 3 | 07-19-2011 11:00 PM |
Superior drummer 2.2.2 causing PT9 to crash | Raoul23 | The Drum Room | 2 | 06-21-2011 02:51 PM |
SUPERIOR DRUMMER 2.0 in PRO TOOLS 9 | Leonidas666 | macOS | 2 | 05-25-2011 01:40 PM |
Choke a crash in Superior Drummer | GuitarSlinger | The Drum Room | 5 | 03-25-2010 10:18 AM |
Superior Drummer + Pro Tools | Mike1983 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-17-2009 04:56 PM |
