Old 05-28-2003, 11:51 AM
jtrolka jtrolka is offline
Default 001 recording start takes forever
Hey, I have a 001 running off of a G4 Titanium via a Magma CB2 expansion chassis using a Glyph compansion (firewire) as my tracking drive. Playback is fine. I hit the spacebar and it goes even with 18+ tracks. Recording though, even in a session with no other audio, it takes PT quite awhile to start recording, maybe as much as 30 seconds after I tell it to record. It didn't used to do this, so I imagine I have switched some button somewhere. I'm in low latency mode, but I belive that's for monitoring anyway, and wouldn't have an impact on this. Any thoughts?
Thanks!
Jeff
002r, Tiger 10.4.3, PowerBook G4 1.5 Ghz, 1.5 Ram, PreSonus DigiMax LT optical in, FMR pre's.
Old 05-28-2003, 03:37 PM
J. Guerrero J. Guerrero is offline
Default Re: 001 recording start takes forever
If you press on the transport the Rec button, then you press the Alt/Option key while clicking the Play button, you'll experiment the pause without Pro Tools actually starting to record and you'll see your system will be unresponsive for a few seocnds. When the pause is over, your system will be back, then just press Play or the spacebar and Pro Tools will start to record instantly.
Old 05-28-2003, 06:06 PM
artguilljr artguilljr is offline
oh yeah make sure your not in quickpunch. when your in quick your essentially recording double the amount of tracks your actually recording. this bogs you down big time.
Art Guillermo Jr.
Owner
Trans-Plant A/V (San Antonio, Tx)
Old 05-28-2003, 06:43 PM
keyboardgod keyboardgod is offline
Have a look at your preferences.There is a setting for how many minutes to give to recording and I think it's 60 by default.try reducing this to 15mins or so
hope this helps
Old 05-29-2003, 12:36 AM
try adjusting your buffer setting in your hardware setup
it's default to 2 but anything higher will make recording really slow anything less will make you have HD cannot keep up errors
Art Guillermo Jr.
Owner
Old 05-29-2003, 12:57 AM
Yeah, I tried playing with the DAE buffer settings last night. I had it set to zero, but I'll have to try some other settings. Thanks
Jeff
PT 10 takes forever to start up DJYoutubeDJ Pro Tools 10 3 06-28-2013 01:39 PM
Pro Tools 11 takes forever to start? hollywoodbeats Pro Tools 11 6 06-25-2013 05:49 AM
PT9 takes forever to start opening Ryan Young macOS 2 12-27-2010 03:51 PM
Pro Tools takes forever to start up livstone Pro Tools TDM Systems (Mac) 7 11-06-2004 08:21 AM
Takes time to start recording Duh! 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-10-2000 08:42 PM
