Old 01-26-2024, 05:40 PM
wh3music wh3music is offline
Default S6 Faders Getting Stiff
Hey all,
On one bank of my S6 M40, some of the faders are getting increasingly stiff. It feels a lot like the motors are fighting me when I'm making a move. The other bank of faders are ok. I've tried restarting the console and noticed the same resistance with the console powered down, suggesting that maybe it's a mechanical problem. Anyone ever see this before?
Old 01-26-2024, 06:21 PM
BScout BScout is offline
Default Re: S6 Faders Getting Stiff
Yes. Had one fader in a bank show resistance. Had to get it replaced.
Each fader is completely sealed (the motor part) so there isn't anything to fix via "lubrication" with graphite power or anything. And removing the fader and manually "exercising" it accomplished nothing. I believe the motors (or ball bearings in the motors) eventually wear out.
So had the one fader replaced under the support plan and asked for a few spare so that there's no downtime in case it happens with another one in the future (which Avid gladly sent a few.) (replacing the fader is relatively easy)
Old 01-29-2024, 09:39 AM
Ahh. I was hoping there was some sort of reset I could do or something. I'll get in touch with Avid. Thanks!
Old 01-30-2024, 10:33 AM
EddieJones's Avatar
I wouldn't use graphite powder, that may cause shorts across the very sensitive touch tracks.
Old 01-30-2024, 10:34 AM
EddieJones's Avatar
It sounds like some dirt or liquid might have got in there. If they are still stiff when powered off, then it's not an electrical/touch issue.
Old 01-30-2024, 01:33 PM
Nothing in the end was used. And the fader was clean as a whistle. (no dirt or debris anywhere -- nothing to blow out, almost surprisingly clean.) Just resistance from the motor that didn't exist on any of the other faders.
Suggestions for getting a non-stiff, warm clean sound? Variable Eleven Rack 2 09-20-2011 10:46 AM
New Starter Scared stiff of installing Dave Atkin Pro Tools SE and Essential (Win) 3 04-09-2011 03:58 PM
Stiff movement of audio files Jon Thomas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-07-2006 10:59 PM
Stiff or lemix - a quick Mbox question Cliffy_Boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-22-2004 03:21 PM
Digi 002 -- some rotary encoders are stiff... some smooth Rains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-12-2003 01:08 AM
